Denon 3802 manual
NeilGabriel
NeilGabriel Posts: 1,487
edited June 2007 in Electronics
I just picked up a new to me Denon 3802 with original remote. No manual. Does anyone have an electronic one? I would guess one for 4802 or similar model would work as well. I didn't see anything this old on the Denon site.
Thanks.
Michael
  • cfrizz
    cfrizz Posts: 13,415
    edited May 2007
  • NeilGabriel
    edited May 2007
    wow...thanks...and I do legal research for a living (but I also have 3rd degree ADD)....I will actually read this, but do you know, and I know you do, whether the 3802 will downmix a 5 channel soundtrack to stereo? Thanks. It is going to be a few days before I get the whole HT thing up and running.
  • cfrizz
    edited May 2007
    I have no idea Neil. If it is a 5 channel soundtrack then I listen to it in 5 channels!
    I think that it would actually be a function handled by your DVD player. I remember having to go in and change the setting from 2 channel default to multichannel on my Pioneer DVD player.
  • engtaz
    engtaz Posts: 7,677
    edited May 2007
    Welcome to da Denon Famalia.
    engtaz
  • cmy330go
    cmy330go Posts: 2,341
    edited May 2007
    Yes. Just set it to stereo.
    HT
    Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
    2 CH
    Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
  • Pablo
    Pablo Posts: 723
    edited May 2007
    My 3803 has a 7 channel stereo setting. (this way it really rattles my head).
    Denon AVR-3803
    RTi-70 Fronts
    FXi-30 Surrounds
    RTi-38 Back Surrounds
    Csi-40 Center
    PSW350 Sub
    Panasonic PT-56WXF95 HDTVSamsung un60JS8000 SUHD
    Denon DVD-2910
    Xbox, Gamecube, PS2, PS3, PS4, xbox360, Wii, WiiU, n64
  • NeilGabriel
    edited May 2007
    the 3802 has that as well...but I only have two speakers connected now and a csi5 on the way and I need to run some speaker wire through the ceiling in the basement to connect the surrounds....
  • Pablo
    Pablo Posts: 723
    edited June 2007
    That ceiling run is always a pain. I did mine when I ripped the basement to the studs. I actually sank my surrounds in between the joists to get them up a little more (otherwise they are kind of close to your head).
    Denon AVR-3803
    RTi-70 Fronts
    FXi-30 Surrounds
    Csi-40 Center
    PSW350 Sub
    Denon DVD-2910
  • NeilGabriel
    edited June 2007
    I got the wire runs made and got the surround sound going...mostly...I just printed off the manual. The previous owner appears to have been big on Neo6 (was he in the Matrix?). My first test was a scene in Aliens and when they blew the door off its hinges and it landed on the ground, my son and I thought the receiver had fallen off the stand the sound was so realistic. Also listened to the Eagles concert in DTS. Only issue I am going to have is that rears are only a couple feet behind listening area. Fronts are about 6-8 feet. This is the living room and moving the furniture is not an option.
  • cmy330go
    edited June 2007
    ...Only issue I am going to have is that rears are only a couple feet behind listening area. Fronts are about 6-8 feet. This is the living room and moving the furniture is not an option.
    That shouldn't be much trouble. Just adjust the speaker distance settings on the receiver and enjoy.
    HT
    2 CH
