db351
edbert
I have a 2000 Grand Cherokee with the Infinity system and the front tweets were blown. I decided to check out the db351's to see if they would work as replacements and boy what an improvement. They come with their own bass blocker(which was used and needed since that is the reason that the original speakers blew) and just barely fit. It helps to keep a stock look but with better than stock sound. They are still powered on the factory amp and I am sure would sound better with more power, but for the time being they are a wonderful upgrade. Just wanted to let you know in case someone was either considering getting these or had the same vehicle and issues(because if you have a 1999-2004 Grand, you have these issues).
I know just enough to be dangerous, but don't tell my wife, she thinks I'm a genius.
Pioneer VSX-816
Monitor 40's - fronts, bi-amped
Monitor 30's - surrounds
CS1 - center
PSW10 - I'll let you guess
Blue Jeans Cable - speaker cable
Daewoo 27 incher - one step up from a console
Sony Progressive scan DVD
XBOX
SOPA since 2008
Here's my stuff.
Pioneer VSX-816
CS1 - center
XBOX
SOPA since 2008
Here's my stuff.
Post edited by edbert on
