using a multimeter to get a perfect gain structure
ilikesound
does anyone know what my multimeter should read if i were driving a pair of momo 6.5's and momo 6x9's from a c400.4 amplifier? what is the ideal gain setting for each channel and what should it read? also, if i were to drive a momo 8'' sub from an alpine mrp-m450 monoblock, what should that read? help would be greatly appreciated!:D
At Home:
Panasonic 42'' TC-L42U12 LCD
Pioneer VSX-80TXV
Toshiba HD-XA2
Sony PS3 - psn "metalguitars"
Xbox 360 - gamertag "giggidygiggidy"
Panamax 4300EX
Polk RTi8's
Polk CSi3's
Polk FXi3's. (x2)
Martin Logan Dynamo (x2)
Audioquest interconnects and wires.
Away From Home:
JVC HDR-50
stock system in new car for now:(
Pioneer VSX-80TXV
Toshiba HD-XA2
Panamax 4300EX
Polk RTi8's
Polk CSi3's
Polk FXi3's. (x2)
Away From Home:
JVC HDR-50
Post edited by ilikesound on
You need the Autosound 2000 CD #104. Play the -6 db tracks and use an o- scope to see when the signal starts to clip.
hav you seen the tutorial on the JL website about setting gains? that is why i ask, they have a chart that you can cross-reference for their amps which is why i askAt Home:
Pioneer VSX-80TXV
Toshiba HD-XA2
Panamax 4300EX
Polk RTi8's
Polk CSi3's
Polk FXi3's. (x2)
Away From Home:
JVC HDR-50
stock system in new car for now:( -
There are too many variables to consider. Like the HU output voltage (3/4 volume doesn't seem very acurate), the battery supply voltage for the amp (from the battery), crossover settings, etc. It's a good start, but not the best method out there. I don't think we have any such settings. I'll forward this to Kim.
I've been generating 60 Hz tones, throwing them onto a cd, and then playing them. Lets you measure with a 5 dollar hunk of junk meter... but its not going to give you any idea of where clipping is... I only use it AFTER I've set my gains, as a way to make sure that I'm getting the same power to the left and right speakers.
I'll set the left, set the right, and then check them volt with the test tone / meter, and use the lower value of the two as my setting.
It's only for 'balance' (or 'fade' if you're so inclined).
Lacking a scope, I agree wholly with Kim as to how you should set your gains. If you've got a scope, then have fun.The Artist formerly known as PoweredByDodge -
Kim gave the best answer on how to set gains. Ive been setting them that way for over 15 years and have yet to blow a speaker. Nothing wrong with using a multimeter but a speaker will be more than happy to tell you when its being overdriven.
