11T crossover question
riglehart
riglehart Posts: 276
edited May 2007 in Vintage Speakers
I'm putting new PolySwitches in my 11T (Thanks Ken!). On one crossover I noticed one of the big rectangular resistors has a huge brown spot in the center, like it got very hot. Is this normal, or does it surely need to be replaced. Maybe this is why the switch was opening.
I can't check it with an ohm-meter unless I remove it, since it is parallel with an inductor, I think.
Jolida Tube
Polk 11T, 7, 5, 5jr, 4
Standard equip not worth bragging about.
Post edited by riglehart on
    F1nut Posts: 52,244
    edited May 2007
    That one is cooked, time to replace.
  • george daniel
    george daniel Posts: 12,096
    edited May 2007
    You might consider replacing it with a Mills resistor. Good luck and have fun.:)
    heiney9 Posts: 25,612
    edited May 2007
    That would be ideal, but then if it were me I'd replace them all (in both speakers) with Mills and then why stop there. Rebuild the whole x-over. It seems by the pic you have to remove the caps on top anyways to get at the resistor
