Shanling CDT100A Owners
VR3
Try the Analog Output stage..
I like it...
Lil brighter than the tube - otherwise sounds the same. I like it...
Did I say I like it? Because I do.
I think I need some silver cables in my system too -- maybe between the source and the preamp, just to add even more brightness/detail. Because I like forwardness.
I like it...
Post edited by VR3 on
You mean the solid state output stage? The tube stage is analog also.
Doesn't this player offer a choice of Digital, tube, and solid state output?Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
Yes, Solid State...
Yep - digital, tube, solid state...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
which player did you have before. i have oppo dv-970hd and i am wondering if tube cdp like Original CD-A8T will be a HUGE difference or just minor ?
HUGE.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
The CDT100A was a nice upgrade to my Onix XCD 88 ---
I think I kind of like the Solid State output better than the tube though... Just a FWIW- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
ok. we are in this thread now.
i will listen to tubes in local store. and might buy one of those chinese players.
thanks -
Worst case --
You get a cool looking CDP to look at- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
That particular unit has parts upgrades in the digital signal path. I always thought all the outputs were quite good.
Does the Solid State output stage have the variable output gain that can be controlled via the remote as well? I'm running sans preamp at the moment.
Vr3MxStyler2k3 wrote: »The CDT100A was a nice upgrade to my Onix XCD 88 ---
What tubes have you been using in the tube output stage?
Also, FWIW, its my understanding that the headphone output is supposed to be excellent. -
Yes. -
Im using the set of tubes Mike threw in with the CDP...
I just like the Solid State outs a lil better for my taste...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Vr3MxStyler2k3 wrote: »I think I need some silver cables in my system too -- maybe between the source and the preamp, just to add even more brightness/detail. Because I like forwardness.
careful what you wish for... silver cables can be to much of a good thing.PolkFest 2012, who's going>?
Yeah... I don't think I am...
I changed the output on the CDP, repositioned the speakers and slid the TV back about a foot or so and am digging the results...
Has a much more forward, dynamic presentation and the soundstage is huge.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Well - your CDP looks really nice already, even when it's off!
Glad to hear that the room re-arrangements helped the sound.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Yeah, I am giving it a lil more of the display it deserves- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I absolutely hate cleaning that CDP... lol- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
That's a nice piece of gear.
Wonder what's next after the Stratos Extreme monoblocks, the 2nd VMPS sub, and additional Crown XTi1000 amp? You need a front projector.polkaudio RT35 Bookshelves
Im not going to get another Crown amp...
I'm thinking of getting a HT processor instead of a second VMPS... just for crossover and LFE features and such.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
It sounds like you've reached the "tube" saturation point of your system......too much of a good thing causes a loss in detail.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Yeah... the Candela has a heavy based tube sound. Very smooth sounding preamp.
The Shanling's Solid State output is crystal though.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Vr3MxStyler2k3 wrote: »Im not going to get another Crown amp...
I'd recommend something from Outlaw or Emotiva. There are some good offerings from Rotel, Parasound, Krell, McIntosh, too.polkaudio RT35 Bookshelves
Probally will go with Emotiva LMC 1 just because it is 13" deep and I can put it in my side cabinet and it gives me all of the processing power I will need.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Good choice. I think you're headed in the right direction. I like the components you choose, too.
However, I've stopped upgrading a while ago. I'm like 100% content with my system right now.polkaudio RT35 Bookshelves
BTW Trey, can you chime in on the "Auto Repair dishonesty" thread? I've got a few questions I think you can answer over there.polkaudio RT35 Bookshelves
Heck, I'm 100% satisfied with my system... a month ago.
Before it is over, I will get that other VMPS... the processor... add two more panels... and cables..
I dont really know what to do - don't really need to do anything.
But I did make room for my Mono blocks by putting the CDP up on top of the TV stand. Thats good news.
And I did stay at a Holiday Inn Express last night.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Cool. When are you getting the monoblocks?polkaudio RT35 Bookshelves
Probally mid/end of June.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Good luck with that. I know you will enjoy the monos - they provide more power than you will ever need!
Nice upgrades man.polkaudio RT35 Bookshelves
Vr3MxStyler2k3 wrote: »Try the Analog Output stage..
I like it...
Okay, I tried it, and Sid is right, the SS output stage is pretty impressive. I certainly like it better than the tube stage, and its probably not going to be going back to tubed for a while.
Not sure if its the synergy, or that I just like the first SS only setup I've ever had, but whatever the rig has right now is working.
Good rec' Sid. Glad I switched over and gave it a try.
