Question about In-Wall Center speaker placement
Does anyone know exactly how close the in-wall speakers can be mounted to a television before it causes interference. I was thinking of using 3 LC265i in the front and I thought I read somewhere that they weren't Magnetically shielded. I have plenty of room for the front L/R but I don't have much room for the center. I built a cutout into the wall so that the front of my tv will sit flush with the wall and I would like the clean look with the in-walls. The problem is that I have 8ft. ceilings in the room and my 70"XBR2 is just short of 4ft. tall and is sitting right about 2ft. from the floor.
Also if anyone else out there is using 3 LC265i speakers in the front I would love to hear what you think of them.
Post edited by DMS44 on
I think our member scompracer is doing exactly what you want, he is an excellent resource on the LC265i, I suggest you shoot him a pm if he does not see this thread.
He is always very helpful. I do not see a problem for you, however, Polk does now offer a center channel for in-walls complete with a perfromance enclosure as it is specifically designed as a center channel it will certainly take care of your need.
RT1
