multi vs single cdp - obvious difference?
jabrax
jabrax Posts: 315
edited June 2007 in Electronics
I did some searching on the forum for sound differences between multi and single disc cd player. I enjoy the ability to load up and let it spin randomly.
I can understand the physical differences between the two, things like noises why changing disc.
Are there any differences in sound and what processes within the player would cause them?
TV...............Hitachi 42hdS52a plasma (sexy one with the swival)
Pre/Processor - Emotiva MMC
Seven Ch AMP - Emotiva LPA
Fronts - Tyler Acoustics 7U's
Center - Polk LSIC
Sub - DSWPRO600
DAC - Music Hall 25.3CD - Marantz cc4001
Blue Ray - PS3
Speaker cables - Audioquest cv4 dbs
Interconnects - MIT AVT1's
Power Filter....Monster HTS 3500 MKII
Post edited by jabrax on
  • Refefer
    Refefer Posts: 1,280
    edited May 2007
    The basic idea here is the more electronics there are, especially motors, lead to more noise in the channel.
    My ears aren't good enough to tell the difference, so YMMV.
    Lovin that music year after year.
    Main 2 Channel System
    Polk SDA-1B,
    Promitheus Audio TVC SE,
    Rotel RB-980BX,
    OPPO DV-970HD,
    Lite Audio DAC AH,
    IXOS XHA305 Interconnects
    Computer Rig
    Polk SDA CRS+,
    Creek Audio 5350 SE,
    Morrow Audio MA1 Interconnect,
    HRT Music Streamer II
  • janmike
    janmike Posts: 6,146
    edited May 2007
    My opinion has always been that single cpd's have better sound.
    Michael ;)
    NORTH of 60°
  • Spacedeckman
    Spacedeckman Posts: 96
    edited May 2007
    There are very few multi-players that have what it takes to be a good player. Just not much of a market for them I guess. Most of the good sounding pieces tend to be single discs.
    Given that, you could use a better D/A on a multi-disc, which could be as cheap as using the digital input on your receiver. If you aren't using a receiver, then any outboard DAC will be better than what comes in a garden variety CD changer. I chanced on mine, but it is actually a DVD player that just happens to have the chops to be a high end CD player. Not many of those either.
    I guess, like record changers before them, the more audiophile market tended to avoid changers, and the manufacturers followed their lead.
    Mark
    System:
    VPI Scout/Benz Ace
    Sutherland PH2000
    Arcam CD72
    Yamaha DVD-CX1 (primarily for CD..26 lbs, all BB D/A)
    Audioprism Mantissa w/Reference PS
    Parasound HCA750 (temporary)
    Audiovector M1 Signatures
    Kimber 4TC x 2
    F1nut Posts: 51,673
    edited May 2007
    The transports in spinners leaves much to be desired.
  • jabrax
    jabrax Posts: 315
    edited May 2007
    Interesting
    Case study - Marantz has 2 cd players, cc4001 (multi) and cc5001 (single). They both appear to have the same major electroncs (dac etc,). The 4001 is a few bucks more I assume do to the multi disc feature with identical electronics.
    Is the common thought (in theory) that the 5001 would sound better do to less demands on the circuitry?
    Center - Polk LSIC
    Sub - DSWPRO600
    Blue Ray - PS3
    billbillw Posts: 7,457
    edited May 2007
    The real idea is that the single disc transport is more sturdy and spins the disc with less vibration, etc. In practice, I don't think there is much difference unless you are talking about the really well built single disc players like the TOTL Sony ES or Pioneer Elite.
    FWIW, I'd put my Sony SCD-C333ES changer up against just about any single disc for sound quality. Its a 25lb changer that's built like a tank, and has excellent electronics to boot.
  • sucks2beme
    sucks2beme Posts: 5,681
    edited May 2007
    There are serveral good multi disk CDPs. Don't expect to find them cheap.
    Look to the same brands that make the single disks that are good.
    I screwed up a couple of months ago when I didn't snag a great
    deal on an Arcam Alpha MCD
  • steveinaz
    steveinaz Posts: 19,545
    edited May 2007
    In theory there should be no difference. The disc "handling" has changed, and nothing else. The problem is, most companies base their changers on the cheaper versions (electronically) of their standard single-disc players.
    Why more high-end changers aren't made, I have no idea. Rotel is about the only one I would own.
  • Sherardp
    Sherardp Posts: 8,038
    edited May 2007
    I too own the Marantz, I went from a low end Sony to the CC4001. I now experience the open soundstage, and hear the seperate instruments in Jazz, classical music, etc. Granted Im using good cables as well, to include Signal PowerCord, and Signal Cable Silver IC's so that may make a difference to some, and not others. The player is rather noisy only during disc changes, not during playback of any sort. Then again I wouldnt say it was too noisy as to think something was wrong with the player. I purchased a CC4300 and experienced the grinding etc, sent it back to audioavisor and went back to the Sony before going to the new CC4001. Im all for it, and may even try using an outboard DAC to see if the player has even more potential.
  • WilliamM2
    WilliamM2 Posts: 4,804
    edited May 2007
    Get the best of both worlds. Single drive, and holds around 500 discs on the internal HD, very convienient. The specs claim 200GB, but mine arrived with 300GB.
    http://www.yamaha.com/yec/products/productdetail.html?CNTID=200106&CTID=5002200
  • Sherardp
    edited May 2007
    WilliamM2 wrote: »
    very nice
    VR3 Posts: 29,387
    edited May 2007
    I thought I would never like single disc cd players.
    After switching to them - I will never go back to multi-disk changers.
    Sound better, arnt noisy ---
    And you cant switch between disc on the fly so you are more selective of your listening. And enjoy it more.
    Not to mention they last longer and the BQ is usually a lil tighter.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited June 2007
    It seems as if the manufacture's generally target changers to those not interested in Audio Sound Quality, another example how the convenience of a device can outway certain negative qualities. I suppose they figure if a lesser transport, noise and so on do not really bother the listener, then cheaper parts, integrated circuits will not either.
    Your still probably not going to hear a tremendous difference though comparing dollar for dollar until the four figure range of single disc player's.
    I listened to my jukebox today while cruising the board, still an enjoyable experience just not "smoking jacket" time.
    RT1
  • NeilGabriel
    NeilGabriel Posts: 1,487
    edited June 2007
    I've been looking at used Marantz cc4001. Any owners recall what it went for new?
  • Spacedeckman
    edited June 2007
    WilliamM2 wrote: »
    I've got a lot of vinyl I would like to burn onto disc, I'd really like one of those, wanted one for a long time, but haven't pulled the trigger. Pretty good D/A and A/D converters in it too.
    Mark
    System:
    VPI Scout/Benz Ace
    Sutherland PH2000
    Arcam CD72
    Kimber 4TC x 2
    treitz3 Posts: 19,945
    edited June 2007
    When you go with audio gear that pleases the consumer with "convenience", then the focus turns away from audio to do just that.
    Audiophiles go for one transport to no transport, or vinyl. John Q. Public who is interested in convenience will get his convenience, but it will sacrifice on the sound. Why do you think MP3's sound bad? They are convenient.
    Do you want to have convenience, or the best sound possible?
    SACD is pretty much known as an audiophile format. I have yet to run across a multi-disc SACD player. You figure it out.;)
  • Sherardp
    edited June 2007
    I paid 328.00 from one call ,you can find it @ http://www.onecall.com/ProductDetails.aspx?id=34686
  • Sherardp
    edited June 2007
    treitz3 wrote: »
    You havent looked really hard brother. Here you go
    http://www.onecall.com/ProductDetails.aspx?id=25152
    edited June 2007
    I stand erected.
  • NeilGabriel
    edited June 2007
    Sherardp wrote: »
    What can you report about onecall? I never bought from them. It looks like an electronics place and not another amazon, right?
  • engtaz
    engtaz Posts: 7,669
    edited June 2007
    I have had no problems with them on stuff I have ordered.
    engtaz
  • cmy330go
    cmy330go Posts: 2,341
    edited June 2007
    Mark
    I know someone who could get you a great deal on one.;)
    HT
    Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
    2 CH
    Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
  • Spacedeckman
    edited June 2007
    cmy330go wrote: »
    Spent it on a phono stage, know what I mean? :D
    System:
    VPI Scout/Benz Ace
    Sutherland PH2000
    Arcam CD72
    Kimber 4TC x 2
  • Spacedeckman
    edited June 2007
    treitz3 wrote: »
    It's not that it can't be done, or that it hasn't been done, it's just that the target audience for higher end gear just isn't interested, at least enough for manufacturers to make a commitment to it.
    My Yamaha was a total marketing flop. High performance DVD changers that can play CDs commensurate with players at or above the price level. Sounds like a winner, but it just didn't sell in any quantity. No market. I'd like the unit better if it were a single disc, personally, but it isn't giving up any noticable performance being a changer. Then again, it was $1400 retail. Gotta love a big power supply, solid transport, and top end Burr Browns. Recipie for success....unless you wanted to sell them.
    System:
    VPI Scout/Benz Ace
    Sutherland PH2000
    Arcam CD72
    Kimber 4TC x 2
  • cmy330go
    edited June 2007
    Boy do I. Two as a matter of fact.:D
    HT
    2 CH
