WTB: SVGA (HD-15) to 5BNC cable
Serendipity
Hi,
I'm looking for an SVGA (HD-15), 15-pin on one end to a 5BNC breakout cable. This is to connect an HD source such as an HDTV receiver or HD tuner to my CRT projector, which only accepts 5BNC connections.
Thanks!
Thanks!
polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
Post edited by Serendipity on
Check Ebay I have seen them every once in a while. Also a more expensive route is SVGA to rca to bnc.
Happy hunting
Ben -
I think monoprice.com sells cheap ones.Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
http://cgi.ebay.com/6FT-VGA-HD15-5-BNC-RGB-Video-Cable-For-Sony_W0QQitemZ220116087537QQihZ012QQcategoryZ41999QQssPageNameZWDVWQQrdZ1QQcmdZViewItem3
Search Ebay for "vga bnc"
You'll see them.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
I think that's an RGBHV cable, right? I tried an SVGA to 3BNC (used for digital projectors such as InFocus and it did not work).polkaudio RT35 Bookshelves
Thanks, I found one.polkaudio RT35 Bookshelves
