Totem Acoustic Thunder Subwoofer?
SolidSqual
How do you guys feel about the Totem Thunder Subwoofer? I'm debating buying one of these over the new 13" SVS subs. I have Totem Rainmakers and aboslutely love them. In fact, when I get a chance, I will be moving up to the Forest line. Until then, I want a good sub to round out my bottom end. Totem does such an amazing job creating music with their speakers, could they do the same job with their subs?
I'm trying to understand the 2 passive radiator design. Does anyone know how it works? I can't find any articles.
http://www.totemacoustic.com/english/products/subwoofer_thunder.htm
THUNDER
Totem's "Thunder" incorporates exquisite cabinetry, advanced design features along with multi role usage.
Its unique front-firing active driver shares external cone topography, materials and features with the two flanking passive units. This we believe allows for a more informative and continuous energy flow.
Designed for cinema/surround applications where it excels, it nonetheless performs admirably well as a bass module for stereo or multichannel audio use.
It intermeshes seamlessly with all Totem products for any task where bass augmentation is required.
The Thunder can actually reproduce musical bass harmonics concurrently with quick, low, accurate bass extension: Quite a feat!
For a more informative and continuous
energy flow
Specifications
Frequency Response 20 Hz to 200 kHz (in room)
Amplification 500 W max.
Phase Adjustable / Variable
Volume Adjustment Yes
Frequency
Adjustment Yes (40 Hz to 120 Hz)
Line Level Connections 1 pair RCA input
1 pair RCA unfiltered
Driver 10" (26cm) variable shaped non resonant metal
cone with carbon graphite conical dust cap
Passive Radiators 2 x 10" (26cm) variable shaped non resonant metal cones
Dimensions w 12 x d 18 x h 18.5”
w 300 x d 455 x h 468 mm
THUNDER
energy flow
Specifications
Frequency
Post edited by SolidSqual on
Will the sub be used for 2-channel music only? If so, I'd give it a try. I like the fact that it has dual passive radiators.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Yes I'm primarily using it for 2 Channel. It will be paired with Totem Rainmakers and LSi15s. I have an Adcom GFA-600 speaker switcher. As I couldn't pick which set I liked better.
Get the totem sub... I think it would be more "synergistic" since it is made by totem.
Hehe, I also have an adcom selector (GFS-3), they are good selectors aren't they... it's nice to be able to "play" with a few sets of speakers.
