Monster Power Conditioner
Early B.
For sale is a modded Monster PC1000 power conditioner in very good condition. I have been using this power conditioner for my HT system. This unit has been modded by reducing the length of the cord from 8 ft. to slightly less than 4 feet because the cord was unnecessarily long for my application. I also added a hospital grade connector. This unit currently sells for $149 here: http://www.ramelectronics.net/HTML/MPPC1000.html
Price is $49 shipped CONUS. PayPal is preferred.
Designed by world-renowned AC power expert Richard Marsh, Monster's Clean Power circuitry uses sophisticated non-resonant filters to reduce RFI, EMI and other distortions typically found on the AC power line. One filter bank offers extreme low-noise filtering, the other radically wide-band filtering. And each bank of filters is isolated from each other! The PC 1000 is made of heavy, industrial-grade aluminum for rugged, long-lasting protection, performance, and convenience. You'll get everything you paid for without wasting your business day dealing with lock-ups, computer crashes, data loss, and other pollution-related power line problems.
PC1000 Specifications:
Stage 2 Clean Power Circuitry engineered for Home Office applications offers superior system and peripheral performance, helping prevent computer lock-ups and crashes.
Four unswitched outlets provide 500 watts of isolated, filtered clean power
Color-coded outlets for easy identification
"Ground OK" indicator shows if house wiring is properly grounded
Phone/Fax/DSL line surge protection
Four switched outlets provide 1500 watts of isolated, filtered clean power
"Protection On" indicator
Coax protection for cable modem, cable TV and satellite connections
Color-coded labels prevent data loss from inadvertent disconnection
1665 joule rating provides highest level of surge absorption
Width: 18.5 in.; height: 2.5 in.; depth: 4.8 in.
HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes."
Post edited by Early B. on
I already have a good unit covering my computer gig but this is hard to pass up. I'll let it go to the next guy but man... this is a good deal IMO.Never kick a fresh **** on a hot day.
Car Setup: OEM Radio, RF 360.2v2, Polk SR6500 quad amped off 4 Xtant 1.1 100w mono amps, Xtant 6.1 to run an eD 13av.2, all Stinger wiring and Raammat deadener. -
Hi Early,
I will take the ps conditioner. I need one for two systems so it will work somewhere. I will try it on the 2 ch system first. I will pm you. Thanks.Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
Bottlehead Eros
CD: DIY Shigaclone
Vinyl rips: ESI Juli@24/192->Goldwave->i7 PC server -
Put me next in line if something doesn't work out, thanks."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
This item is still available. PM sent to bikerboy two days ago, but no payment yet. Face, you got a PM.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Hi Early,
Sorry I didnt get back to you sooner. I am working 5-12 hr shifts at a level 1 trauma center so we have been busy this holiday weekend. I will paypal you the money now. Thanks, JeffMain system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
Bottlehead Eros
CD: DIY Shigaclone
**sold**HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Hi Early B,
Just unpacked the conditioner. Looks good. Dont know if it will help with the 2 ch rig till I try it out. If not I will use it for the computer. Thanks.Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
Bottlehead Eros
CD: DIY Shigaclone
