1 problem...
sntnsupermen131
whoever...
im running 2 mm120s off of a rf bd1000.1 amp
i have 1 sealed box with seperate sealed chambers that have been reinforced and a pound of polyfill put in each chamber
my problem is at louder listening levels they begin to pop when the bass hits
(btw--the punch bass is all the way down)
do you think i have a wrong setting on the amp or what?
i have since forgotten what the settings on it were but i do remember the Hz frequency is set pretty low
i have them under the back seat of my 96 extended cab chevy
and one sub does it more than the other
but i can only really hear it when i move the front seat forward
its about 5 inches or so from the woofer
any help would be appreciated
-cody
-cody
Post edited by sntnsupermen131 on
sounds like your gain is too high, and you may have slightly damaged your woofers.... first off, crank the gain down a bit and if the problem dissipates, then be happy, otherwise you may need to get your momo's replaced/fixed.
the punch bass knob is a lot different than the gain.... the gain for lack of a better word, "amplifies" the whole spectrum of sound going through your amp... the punch bass only "amplifies" a certain frequency range. you'll most likely want your low pass cutoff point set somewhere around 80Hz
Other than your problems, sounds like a nice setup, i've got basically the same thing, except i've got the new momo's with enclosure... bd1000 mono block, with a pair of MM12's... and EX3 6x9's and 5 1/4's and a pair of fosgate 3 1/2" 2 ways for my midrange -
i had teh same junk happen to me a few times... one time i blew the crap out of a sub and fried the voice coil...
this latest time i think i only marginally hurt them..lol.. i refused to allow break in, and hten i had too big of a box.. this caused over excursion and crappy sound / flapping.
after a while, i figured it all out, cut the box down to proper size, and let teh subs rest...
now its about 90% as good as it could abeen had i done it right to begin with.
but ya.. haviing that punch bass at anything more than half is suicide for the subs. and the gain over 70% is a killer too.The Artist formerly known as PoweredByDodge -
thanx guys
ill look at the gain
but the box is .88 per chamber
or i took it to get it modified and thats what it sposed to be
but it looks right
-Cody
