Stand up, lie down?
NeilGabriel
NeilGabriel Posts: 1,487
edited May 2007 in Speakers
I plan to use some new Monitor 5s for bookshelves and want to lie them on their sides. In the day, before half the board was born, I was told that you should not do this to a speaker intended as floor standing. But then I was told a lot of stuff...."hey smoke this, it won't affect your brain". Anyone see a problem to lying these down. I know someone here does this with 7s. Thanks
    heiney9 Posts: 25,430
    edited May 2007
    For 2 channel listening I'd say no way. As a surround it probably would sound alright. I doubt you would do any damage to the magnets, etc. if that's what you are asking
  • NeilGabriel
    edited May 2007
    heiney9 wrote: »
    Any damage is an issue (if someone says so). I was more concerned about SQ since the speaker wes constructed to have the drivers on top of each other and not beside one another. Maybe a dumbshot question.
  • Willow
    Willow Posts: 11,229
    edited May 2007
    in my current set up my rti4's are on their backs for surround duty and it does the trick !
