NOS tubes causing Tranny hum?
cbl117
cbl117 Posts: 285
edited May 2007 in 2 Channel Audio
Is it possible for "new" NOS tubes to cause transformer hum? I put a matched pair of mullard 12at7 and a matched pair of sovtek 12ax7 lps into my pre and now there is a very faint hum coming from the transformer.:confused:
Vandersteen 3a Sigs
Music Reference RM-200
Hovland HP-100
VPI Scout w/ Benz Ace
Rotel RCD-1072
Cardas Golden Reference Speaker Cables
Cardas Golden Reference Interconnects
Cardas Golden Power Cords
PS Audio UPC-200HB
Black Diamond Racing Isolation
Post edited by cbl117 on
  • candyliquor35m
    candyliquor35m Posts: 2,267
    edited May 2007
    I don't know if it's possible but you could take the nos tubes out and put the previous tubes back in to see if the hum goes away.
  • cbl117
    cbl117 Posts: 285
    edited May 2007
    I should do that, but I'm lazy and wanted to see if anyone had some ideas. :o
    Vandersteen 3a Sigs
    Hovland HP-100
    Rotel RCD-1072
    PS Audio UPC-200HB
    F1nut Posts: 51,766
    edited May 2007
    Bad tube(s) cause all kinds of noise issues. Swap the known good tubes back in one at a time to determine which are bad.
  • cbl117
    cbl117 Posts: 285
    edited May 2007
    I tried plugging the preamp into a different outlet and the mechanical transformer hum is gone. The new outlet I tried is on a different circuit. I'm in an apt, so maybe there is some DC in my AC causing the coils in the transformer to get polarized.
    After this experiment, I'm assuming its not the tubes. But can someone confirm my hypothesis.
    Can anyone reccomend a power conditioner that cleans AC noise AND gets rid of DC?
    Vandersteen 3a Sigs
    Hovland HP-100
    Rotel RCD-1072
    PS Audio UPC-200HB
    F1nut Posts: 51,766
    edited May 2007
    No hum with old tubes. Hum with new tubes. No hum when plugged into different outlet with new tubes. I wonder if the hum would return if you put the old tubes back in while connected to the different outlet?
    You're making this more difficult than it has to be. Go back to the original outlet, replace the tubes one at a time, see what you come up with before doing anything else.
  • cbl117
    cbl117 Posts: 285
    edited May 2007
    Survey says...hum with old tubes in original outlet. No hum with original tubes in new outlet.
    F1nut, will NOS that are considered "new" need time break in? I feel like every damn time I sit down to listen, it sounds different. The frequency spectrum seems all over the place.
    Vandersteen 3a Sigs
    Hovland HP-100
    Rotel RCD-1072
    PS Audio UPC-200HB
    F1nut Posts: 51,766
    edited May 2007
    Ah!
    Yes, they will need to burn in. 50 hours or so should do it.
