Using old monitors as surrounds?
polksda
One of my RTA11Ts that I've been using for my surrounds in my 5.1 setup just gave up the ghost... and I haven't been real thrilled with the performance anyway as of late.
So I'm unsure what I should replace them with.
I have an extra pair of Monitor 5b, as well as Monitor 7s, and Monitor 10s.
The 5bs would be the easiest to deal with from a size perspective. Anyone using them for rear surrounds? I assume I would want to change my receiver setting from "Large" to "Small" using the 5bs?
My front mains are SDA SRS 1.2s.
Thanks.
Thanks.
Post edited by polksda on
I have 10Bs as fronts, 7's as my surrounds in 5.1 with a 5 as the center. I have them all as large since they all produce decent bass and that is all my small/large system set up is based upon. I am very happy with my sound, but I am far from the pickiest guy on the board. I did have 5s before I moved the 7s in, but I also had totally different equipment with them so I can't compare.
I have 4's as surrounds, they work great.Monitor 7b's front
Monitor 4's surround
M10's back surround
Harman/Kardon AVR-635
Oppo 981hd
Denon upconvert DVD player
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek: -
Bump. Any other folks using Monitors for surrounds?
5jr+ set to large and 4" from the rear wall. Sal, try adjusting the output level through your receiver or use pre-out and a seperate amp. 5's can play up to around a 100 watts clearly with a high current amp.
Steve -
I have had no problem using 7s for rears. My 5 as center gets pushed a little when I am really cranking something and so I throttle back. When I tried to use a 5jr+ as center, it was just a little different in tone/timbre and noticeable. Even when I did test tone, it sounded different from 10s and 7s. That could be unique to my system.
5jr's for years and then switched over to Atlantic Technology.
I've used Monitor 11's as rear/surrounds in my smaller 5.1 system with SDA 2B's and RTA-12C's as front/mains. Sounded great. Only reason I changed was the acquisition of two pair of RTA-8T's which gave me a smaller gear footprint in the room.
I use a set of RT800i's as surrounds with exceptional results!
