Sda 1.2 Tweeter Problem, Crossover?
KENCAD
KENCAD Posts: 10
edited May 2007 in Vintage Speakers
I Am New To The Forum And Not Sure How This Works. I Have A Pair Of Sda-1.2's And My Left Channels Highs Are Virtually Out. I Contacted Polk And They Sent Me A New Tweeter To Try Out But It Didn't Work. I Have Switched Speaker Wires From Left To Right And The Problem Was Still On The Left. I Also Put Another Receiver On The Speakers To Make Sure It Wasn't My Amp Or Pre-amp. I Feel It Is My Crossover But Not For Sure. Can Any One Help?
Thanks, Kenny
Post edited by KENCAD on
  • read-alot
    read-alot Posts: 812
    edited May 2007
    Do you have the IC cable hooked up?
    polkaudio SRS (rdo194 x 8)
    Dodd ELP (separate power supply)
    JC 1 blocks ( strapped )
    Rega Apollo
    MIT (speaker cables) Outlaw (ICs)
    polkaudio SDA2(rdo194x4) (front) polkaudio CRS (rdo194x4)(rear) polkaudio 400i (center)
    B&K 505
    Samsung LCD
    VIP 622
    HSU STF-2
  • KENCAD
    KENCAD Posts: 10
    edited May 2007
    My Cable Is Hooked Up.
  • read-alot
    edited May 2007
    Have you looked at where the tweets hook up to the crossover. Highly unlikely for all four to go out at the same time.
    Rega Apollo
    B&K 505
    Samsung LCD
    VIP 622
    HSU STF-2
  • KENCAD
    KENCAD Posts: 10
    edited May 2007
    I Have Already Tried Putting New Tweeters In The Left Side To No Avail.
  • read-alot
    edited May 2007
    Polyswitch
    Rega Apollo
    B&K 505
    Samsung LCD
    VIP 622
    HSU STF-2
  • KENCAD
    KENCAD Posts: 10
    edited May 2007
    Polk Audio Sent Me Only 1 Tweeter But I Tried It In All 4 Locations
  • KENCAD
    KENCAD Posts: 10
    edited May 2007
    I Don't Understand
  • KENCAD
    KENCAD Posts: 10
    edited May 2007
    I Haven't Tried The Bottom Post Because The Upper & Lower Post Are Linked
  • KENCAD
    KENCAD Posts: 10
    edited May 2007
    Mids And Bass Response Is Great
  • KENCAD
    KENCAD Posts: 10
    edited May 2007
    I Already Switched Speaker Wires And It Didn't Work. The Tweeters Are Working, But Sound Very Muffeled.
  • read-alot
    edited May 2007
    Polyswitch
    Rega Apollo
    B&K 505
    Samsung LCD
    VIP 622
    HSU STF-2
  • KENCAD
    KENCAD Posts: 10
    edited May 2007
    Is The Polyswitch Easily Fixed?
    F1nut Posts: 51,700
    edited May 2007
    KENCAD, your posts are confusing to say the least. However, Read-alot has nailed your problem, you have a bad polyswitch. There is one on each crossover, replace both.
    They are easy to replace as long as you can solder.
  • Ricardo
    Ricardo Posts: 10,636
    edited May 2007
    I am not sure about that "off/on only" on the polyswitch; to isolate your problem to tweeters/polyswitch, do as someone else said; install all your right tweeters in your left speaker; if they still sound muffled, it's the polyswitch; you can get a pair of them from Polk; as someone else also said, it's an easy swap if you can solder.
    SOPA
  • KENCAD
    KENCAD Posts: 10
    edited May 2007
    My Brother Is Looking For A Pair Of Pioneer Hpm-100's Or 900's. Does Any One Know Where He Could Get Any Instead Of E-bay?
  • Ricardo
    edited May 2007
    In the Club Pioneer forum?
    SOPA
    heiney9 Posts: 25,412
    edited May 2007
    KENCAD wrote: »
    Perhaps the local dump or an indigent person's shopping cart. :D . Seriously, I have no idea why he would to listen to those, but check www.AudioKarma.org people on there seem to thinks they are worthy of something and might find some FS. :)
  • ben62670
    ben62670 Posts: 15,969
    edited May 2007
    I have had bad poly switches that made the tweets sound bad, but still played. Order new poly switches from Polk. It is cheap, and easy if you can solder. They do effect all the tweets.
    Ben
    Ben
  • engtaz
    engtaz Posts: 7,669
    edited May 2007
    KENCAD wrote: »
    He would probably get better sound out of Monitor 5's.
    engtaz
    F1nut Posts: 51,700
    edited May 2007
    Lasareath wrote: »
    F1nut,
    I was told that the polyswitches are either on or off like a switch. His problem sounds exactly like mine, he says that the tweeters are playing but they sound muffeled. My1.2tl's had the same exact sound. after I swapped the tweeters i figured out that 3 to 4 of the tweeters were bad.
    He has already swapped a brand new tweeter for the questionable ones (Polk Audio Sent Me Only 1 Tweeter But I Tried It In All 4 Locations), so that leaves only one conclusion, he has a bad polyswitch. The muffled sound that you and he think is coming from the tweeters is not actually coming from the tweeters, but is sound transfered from the mids.
    Right now I have 8 RDO198's and I never did anything to the polyswitches and everything sounds great!
    I would strongly suggest you install new poly's as they degrade with age.
    F1nut Posts: 51,700
    edited May 2007
    heiney9 wrote: »
    WAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
  • schwarcw
    schwarcw Posts: 7,358
    edited May 2007
    Two small alligator clips and a short piece of 16 gauge wire, jump around the polyswitch and see if it makes any difference in the sound quality.
    Anyone have a pic to show our new Forum member with the problem on his SRS's???
    I'll try to find a pic!
    Carl
  • ben62670
    edited May 2007
    Here is what they look like.
    http://www.partsexpress.com/webpage.cfm?WebPage_ID=3
    If they need replacing get them from Ken at Polk Audio.
    Ben
  • schwarcw
    edited May 2007
    Ah Ben, nothing to see!
    Carl
  • hearingimpared
    hearingimpared Posts: 21,136
    edited May 2007
    When I upgrade my crossovers I am bypassing the polyswitchs. Screw them, they just screw up the signal quality anyway.
  • hearingimpared
    edited May 2007
    BTW KENCAD welcome to the club!
  • ben62670
    edited May 2007
    Ben
  • schwarcw
    edited May 2007
    About the size of a dime, the original ones that I've seen are mustard colored.
    Joe's right, bypass those things.
    Carl
  • ben62670
    edited May 2007
    Lasareath wrote: »
    What size are the Polk ones?
    It depends on what model speakers you have. Polk sends you the right ones for free. You just tell Ken what you have. Get them both while you are at it. I personally like fuses. They don't degrade. Hearing Impaired has the right idea if you are careful about cranking it up. Bypass them. Clipping is what generally kills tweets.
    Ben
  • hearingimpared
    edited May 2007
    ben62670 wrote: »
    Whose he? Most amps have protection circuits. Plus if you are feeding you speakers with good clean power with plenty of headroom there is nothing to worry about.
