What a difference a small upgrade can make
McCelery
McCelery Posts: 123
I don't know why I've shortchanged the little 2ch setup I have in my bedroom (where I do 25% of my listening) but I only had 18ga 5-strand lamp cord going to my RT35is. It's the lowest possible quality cable that's actually sold as "speaker cable" and the ends were totally oxidized. Lazy ****. I bought a 50ft spool of XP the other day for hooking up friends' systems and figured why not throw a few feet out for myself? It's certainly nothing special but it's an upgrade nonetheless. I wasn't expecting much, if anything.
The difference is unbelievable!! The strum of an acoustic guitar is so much meatier. Highs are light and airy but without any edge. And bass is natural instead of hollow like before. Everything is just more 3-dimensional.
What's funny is that this is all with an Ipod hooked up with the 1/8th inch miniplug, not even a dock connector. I figured that's where the biggest bottleneck would be. But hell, that just gives me more room for easy improvements, right?
Post edited by McCelery on
  • steveinaz
    steveinaz Posts: 19,545
    edited May 2007
    Welcome to the fray of cable-swapping. I think you'll find that multi-strand copper tends to have a fuller sound, and solid single strand copper a leaner, less grainy sound.
    Enjoy
  • Skynut
    Skynut Posts: 2,967
    edited May 2007
    I was blown away when I replaced my speaker wire and cheap interconnects with befier versions.
    Nothing high dollar but better.
    WOW was what I thought.
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
  • engtaz
    engtaz Posts: 7,669
    edited May 2007
    Congrats on the new sound
    engtaz
  • McCelery
    McCelery Posts: 123
    edited May 2007
    Thanks! I've found the secret to my audio appreciation is to make incremental changes and enjoy them for as long as possible until I'm completely used to it. Then make another incremental (but noticeable change). $10-$50 every few months definitely keeps the costs of this hobby down :)
    Any ideas for the next reasonably priced upgrade for either system? I'm using an Ipod with stereo miniplug hooked into low end Sony (105wpc) and Yamaha (70wpc) receivers, decent cables (Canare biwires in the main listening room), and no subs.
    I'm going after an Adcom 545II...I'm thinking more clean power is the next step for the main room. But maybe an Ipod dock is a better, cheaper improvement...? Newbies love advice :D
  • The Naked Truth
    The Naked Truth Posts: 30
    edited May 2007
    McCelery wrote: »
    Oxidation, corrosion, all those things that shouldn't be there gradually degrade the conductivity and thus the sound quality. It's something you should keep an eye for. If you cut an inch off each end of your speaker-wire once a year or so, assuming they're connected directly to your amp and speakers, you'll notice an improvement in the sound.
    I love postwhores, are you one?
  • Schwingding
    Schwingding Posts: 363
    edited May 2007
    Whew! I was afraid this was going to be another power cord thread.
    FWIW, I appreciated several speaker cable upgrades, audibly noticing differences each time, until I got to 12 gauge solid core and did not like what it did to the sound.
    HT/music rig
    Panasonic PX60U 50" plasma
    Yamaha 5990 AVR
    Onix SP3 tube amp
    bunch of Outlaw 2200 monoblocks
    DUAL SVS PB12+/2 subs :eek:
    Denon 3910 DVD/SACD/DVD-A
    DirecTV HR10-250 DVR
    Onix Strata Mini mains
    Mirage OM10 surrounds
    Polk CSi5 center
    Polk SC80 rear surrounds
    Samsung BDP1000 blu-ray player
    Bedroom rig
    Jolida SJ302a tube amp
    Denon 2910 universal player
    Onix Ref 1 monitors
    Velodyne minivee
  • hearingimpared
    hearingimpared Posts: 21,136
    edited May 2007
    McCelery wrote: »
    Most tweaks and minor upgrades have a cumulative affect.
  • candyliquor35m
    candyliquor35m Posts: 2,267
    edited May 2007
    Just when you think you've upgraded everything, you'll find something else to try. I just upgraded my y-adapters (splitters) from monster to AQ and everything sounds clearer, cleaner and more defined. I sometimes worry that what I'm hearing is wishful thinking but I really don't think so.
  • ben62670
    ben62670 Posts: 15,969
    edited May 2007
    I'm the opposite. I wish it didn't make a difference! I would like to spend money on more drivers, better equipment, anything but wires! But now I know. I was on the other side of the fence when I first started. I have tried many different kinds of wires. Each with their own traits. Now I am Tri amping, so cables that sounded better on the highs can be used on the highs. Same for lows.
    Ben
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited May 2007
    Nothing like some quality wire to help the rig along, glad you got some.
    There is all sorts of wire available and I would recommend trying a few different ones as time and budget permit. Just cleaning the posts with some Caig can "wake" things up.
    Gotta love this hobby.
    RT1
  • Rivrrat
    Rivrrat Posts: 2,101
    edited May 2007
    I'm happy for now with my speaker wire, 10g to the mains, 12g to everything else, but I'm starting to doubt my previous opinion on interconnects. I may pick up a set or two of better IC's for everything that's not running optical and see what happens.
    I had intended on rebuilding my crossovers on my m10b's while I'm on vacation now, but other life situations interfered with that plan.
    My equipment sig felt inadequate and deleted itself.
