Question for homeowners
Shizelbs
How much should a new air conditioner for a 3400 sq ft house cost, including installation?
How much should the service to do the yearly furnace inspection and service cost?
We called for quotes and we think we got some excessively high prices.
Post edited by Shizelbs on
Are you adding A/C to your forced air system or do they have to run new duct work?Michael
Samsung 50" HD DLP
Yamaha RX-V2500
(2) Outlaw 200
Adcom GFA 555
Sony BDP300
Denon 2900 DVD
Lsi9's mains
Lsi7's rear
Lsic center
12.1 SVS driver in 4.53 cuft. tube
Harmony 880 -
Just adding one to a forced air system. The house has already been prepped for the AC unit. -
Truthfully I don't know, but I have been advised by a number of different A/C guys to purchase the largest coil(the actual part inside your house that the air blows past). The reasoning I have been given is the condenser(outside unit) should be at least the size appropriate for your house, but the coil bigger as it gives a larger surface area for the blower to send air past, therefore cooling your house more efficiently.
A few other tips, open up the vents throughout the house, it helps to increase airflow and makes your unit not have to work as hard. And unless you have bad allergies, you shouldn't be getting the expensive Filtrete style filters(looks like a large car air filter) as they severely restrict air flow and make it more difficult to cool or heat your home.
I know you are in Washington and for the most part it isn't all that hot for long periods, but it makes a huge difference for heating as well.
Good luck!I know just enough to be dangerous, but don't tell my wife, she thinks I'm a genius.
Pioneer VSX-816
Monitor 40's - fronts, bi-amped
Monitor 30's - surrounds
CS1 - center
PSW10 - I'll let you guess
Blue Jeans Cable - speaker cable
Daewoo 27 incher - one step up from a console
Sony Progressive scan DVD
XBOX
SOPA since 2008
Here's my stuff. -
Yeah, my neck of the woods doesn't get too hot, but for the few months it is hot, we are pretty miserable.
I haven't seen Frank Z around lately, but you may want to send him an email or PM anyway - I believe he's our resident AC/Heat System expert...
Polkmaniac wrote: »I haven't seen Frank Z around lately, but you may want to send him an email or PM anyway - I believe he's our resident AC/Heat System expert...
Yeah, thats what I was thinking too, but I also haven't seen him around here lately. -
I got a quote to instal/relocate a new A/C unit out side and instal a new furnace/ac unit inside. It is a friend and he is only quoting the cost of the equipment.
He says we can do it for $5000.00 on an 1800 sf house.
This is with no instal charge.
i know that the bigger the house the more the ac unit will cost.Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking -
Two to five grand.Michael
Samsung 50" HD DLP
Yamaha RX-V2500
(2) Outlaw 200
Adcom GFA 555
Sony BDP300
Denon 2900 DVD
Lsi9's mains
Lsi7's rear
Lsic center
Harmony 880 -
Last summer I had Sears come out for an estimate on my old house at 1700sq. feet. in Portland. The key is getting a unit that properly matches up with the furnace system. With permits, odds and ends, etc. I was quoted $4400 for a Carrier. I'll bet you're looking at $6000 for a quality unit that doesn't cause the neighbors to file noise complaints. Just make sure the unit is placed on a solid foundation, if not, the buzzing you hear thru your own walls will drive you nuts.Review Site_ (((AudioPursuit)))
Former Staff Member TONEAudio
2 Ch. System
Cable/Wires: Cardas, AudioArt, Shunyata Venom 3 -
We did a furnace and AC unit replacement: two stage uber high efficiency furnace and a very large AC unit with Puron refrigerant for 1900 sq ft house. Total was $8,000+
I assume Puron is a brand? R134a is the common refrigerant used now for replacement A/C units...For some ungodly reason, R22 is in my A/C unit, and it is only a year old.
R134a is actually cheaper than the harsh ****, since production of it was banned a few years ago (harsh ****)......You can buy a 15LB. drum of R134a at Sam's pretty cheap, if you have a refrigerant certification like me:) -
There goes the audio upgrades budget:(
If you have the forced air system in place, it won't be too bad. Depending on the grade you buy, $2,500 to $6,000. HVAC equipment is like anything else, you can buy good stuff and cheap stuff. Do your research. A large surface area coil is good advice. A thermostat can range in price from $20 to $300 or more. The cheap one will break in a year, but will you need all the programable features of a TOTL thermostat. Do lots of research have four or five reputable people (not Sears) come in and give you recommendations and prices. Please note that some manufacturer's just rebrand units. Contractors can buy the units from a wholesaler and several name badges are inside the unit. There is no scam here, it just how it's done.Carl -
Bill Ayotte wrote: »I assume Puron is a brand?
Chemically, Puron refrigerant is an environmentally sound 50/50 blend of two separate refrigerants, R-32 and R-125. Consumer products featuring Puron refrigerant were first marketed in 1996.
And: PDF
Puron refrigerant (R-410A) is an azeotropic mixture of two hydrofluorocarbon (HFC) refrigerants blended in a 50-50 ratio (measured by mass):
R-32 (difluoromethane)
R-125 (pentafluoroethane) -
The compressor is a scroll type (1/2 gallon-2 liter sized), but the condensor is a large 1.75-2 sq meters. It works quite well!
Don't over size the compressor, especially in a humid area like Warshington. Georgia Power recommends 1 ton for every 600 square feet. I imagine this would work well in the NW as well due to the dampness. The key is to allow the unit enough time to cycle the air through to keep the humidity down. For a 3400 sq ft house a couple of 3 ton or a 4 and 2 ton would be almost perfect. Also go ahead and pay for a higher SEER rating. My dad upgraded by a half-ton and actually had like $100 lower bills due to the massive increase in efficiency.
WesLink: http://polkarmy.com/forums
Panasonic TH-42PHD8UK 42" HDTV | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Wyred 4 Sound STP/SE Pre | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d -
I took some freon hits from a car once, other than that I have no idea what it would cost....wait, where am I?CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Puron is a blend of R-something and R-something else (R32 and ?). It's a 400 series (401, 404, etc) that runs at high head pressures to do its thing.
If you have Puron, MAKE SURE that you keep your condensor coils cleaned (that's the unit located outside).
At high temperatures (that's caused by letting your condensor coil get clogged with crap), any wax in the refrigerant oil comes out of solution and LOVES to migrate to the capillary tubes (the thing that squirts freon into the evaporator coil to cool it).
When that happens ...... it's expensive.
And, yes, they do make wax free oil; hopefully your service tech isn't out to squeeze the last dime out of your install job and does the right thing the first time.
But: KEEP THAT OUTSIDE COIL CLEAN !!!Sal Palooza -
EXCELLENT CHOICE OF COMPRESSOR !!
Scrolls are the equivalent of an M1 Abrams tank; rock solid, accept abuse very well (they will pass liquid within reason), and run quiet. REAL quiet.
It's sometimes hard to tell if the compressor's running when checking a unit out because the condensor fan noise, etc will mask the compressor noise.
They'll run forever.
P.S. Didn't mean to shout up there, but .... did I mention that scroll compressors are awesome ? They don't rotate, they oscillate !Sal Palooza -
Wes
Here in Missouri, the rule of thumb is 750 sq ft per ton of refrigeration.
And, as Wes said, a unit has to run to cool but it has to run to de-humidify.
You can stick a 10 ton unit in a shotgun house (800 sq ft) and, yeah, it'll cool REAL quick.
"Gosh, my unit only runs for 30 seconds and the whole house is cool !" is a bad thing.
Cool and humid is not as good as cool and not humid.
If your unit runs 90 % of the day on the absolute hottest day of the year for your area, you're doing well.Sal Palooza -
I took some freon hits from a car once, other than that I have no idea what it would cost....wait, where am I?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
When we were looking at houses, we got quotes of 3K for a 2500sqft home.
I had a new heat pump-air conditioner installed in Nov 06, my house is 2100sq ft. They replaced the main trunk line & outside unit for 3995.00 with a 10 yr warrenty on the compressor.Its a Trane brand xr 13 I think, which is made by American Standard.My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
I'm getting quotes right now on a Unico AC system. I don't have existing ducts and don't want to put large bulkheads everywhere in my house. It's gunna cost me $8-11k, not looking forward to that, but I won't live another summer with those stupid window units.
~J -
Originally Posted by dorokusai
I took some freon hits from a car once, other than that I have no idea what it would cost....wait, where am I?I know someone who died from that in while we were in high school.
Brain Freeze
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
I recall the price jumps significantly as the efficency gets into the 95+% range. The more effecient they are, the larger the compressor that sits outside your house.
The larger compressor equates to a cooler running unit making it more efficient. (as I recall?) -
disneyjoe7 wrote: »Brain Freeze"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
