Y-Splitters
Grimster74
Grimster74 Posts: 2,577
edited May 2007 in Electronics
I'm sure this question has been asked before, anyone else have both Blu-Ray and HD-DVD and using y-splitters for the 5.1 audio outs? Seems using y-splitters would be a whole lot cheaper than buying an audio switcher which I only know of one and it's $600. If so, I'd love to hear your thoughts on it, if you notice any signal loss or any other complications using this method other than not cutting both units on at the same time.
  • Bill Ayotte
    Bill Ayotte Posts: 1,860
    edited May 2007
    I used y-splitters to bi-amp my tannoys on the 2 ch. HT rig, and I didn't notice any loss, but I made mine with Cardas Crosslink IC cable, so the cable quality may have played a factor in that. I doubt that you would have a serious loss in signal strength....Why not give it a try?
  • Sherardp
    Sherardp Posts: 8,038
    edited May 2007
    For your app I would give the splitters a chance since you play to upgrade your pre/pro here soon anyway. Or you can give the audio switch a try and if you dont notice the improvement, send it back
  • malikarshad
    malikarshad Posts: 527
    edited May 2007
    I have used Cobalt Cables Y splitters to use LSi15 for both 2-ch and HT usage.
    I did not find any loss of signal quality in my setup.
    I would go with Y-splitter route as its cheaper & a simpler option.
    Its a no brainer if you are planning to upgrade to pre/pro with built in DTS-HD & TrueHD decoding. That's what I'm also waiting for.
    Speakers=>Salk Soundscape 8, Soundscape Center,Surrounds-Dali Rubicon LCR, Lsi7
    PreAmp, Amp => Marantz AV8801, ATI 6007 amp, Oppo HA-1 DAC
    Source => Sonore MicroRendu, Oppo BDP-103, Mede8er 600XD, Dune HD Smart D1, Synology DS1813+(16TB)
    Sub - JTR Captivator S2 (Dual 18")
    Power - Furman IT-Ref20i on dedicated 30Amp circuit with Furutech GTX-R outlet
    Screen=> JVC RS-45 projector Da-Lite HP 133" 2.35
