Help with Speakers not loud enough......
EFW
EFW Posts: 28
edited May 2007 in Speakers
My system has been hooked up for a while now, but it just doesn't seem to give me that heart pounding mind blowing sound everyone says it should. I have it hooke up using sufficient wire (Monster Cable 12ga.), and the runs to the 70's and center speaker are not very far (less than 6ft.) the rears are further (about 20ft.). The settings on my AVR are 80 mhz on all speakers, the fronts are set at 4db, the center is 3db and the rear is 3db with the sub @ 5db. With a fairly high volume setting it just doesn't seem to produce the soud so many people describe. Am i doing something wrong? or is it that my ears are more than likely playing tricks on me? Any feedback would be appreciated, thanks for the help..................:cool:
AVR...........Onkyo TX-SR703
TV.............Mitsubishi WD-62627:D
HD DVD.......Toshiba HD-XA2:cool:
Power.........Monster HTS 1600
Mains.........Monitor 70's
Center........CS2
Rears..........Monitor 40's
Sub............PSW12
Cables........Signal Cable
Post edited by EFW on
  • engtaz
    engtaz Posts: 7,669
    edited May 2007
    For some reason I could not get the ump I wanted from Onkyo either and neither could my friend that had the 804 so he went with the Denon 5803 and notice a hugh difference in sound.
    engtaz
  • jakelm
    jakelm Posts: 4,081
    edited May 2007
    Make sure the cinema filter is off....
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • engtaz
    engtaz Posts: 7,669
    edited May 2007
    it was on ours
    engtaz
  • EFW
    EFW Posts: 28
    edited May 2007
    how do i do that?
    Center........CS2
  • jakelm
    jakelm Posts: 4,081
    edited May 2007
    I dont know whats the problem besides that. I have found Onkyo to never lack "umphh". Every Onkyo AVR I have owned and listend to (502, 704 and my dad's 604) has never dissapointed me in terms of power.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • EFW
    EFW Posts: 28
    edited May 2007
    What should I select for a listening mode while listening to music? PLII Music, Neo6:Music, Studio Mix, etc...????????????????/
    Center........CS2
  • jakelm
    jakelm Posts: 4,081
    edited May 2007
    I tend to stay away from the DSP (hall, cinema, etc) and stick with PLII or Neo6
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • BigA524
    BigA524 Posts: 63
    edited May 2007
    Im debating if I should return my onkyo 804..it seem like it wasnt doing mmmuch either..only thing i noticed was my sub sounding better..
    Marantz 1607 - Polk S60 - S35 - Emotiva XPA-3 - Polk DSWPRO550wi
  • jakelm
    jakelm Posts: 4,081
    edited May 2007
    I'm not taking up for Onkyo, but they are one of the few manufactures that give pretty "true" specifications.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • EFW
    EFW Posts: 28
    edited May 2007
    Thanks for all the help guy's, keep the suggestions comming. I was looking at the specs on the Denon 3806 looks pretty good might be an improvement??????
    Center........CS2
  • AndyGwis
    AndyGwis Posts: 3,655
    edited May 2007
    Another option to think about. . .
    Maybe go with a cheap pre/pro or AVR with Pre-outs and a nice multi-channel amp. Separate amps definitely give good oomph, and you can find a decent AVR / Multichannel amp combo for around $1K, maybe less if prudent in your shopping.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • ronnie
    ronnie Posts: 150
    edited May 2007
    go with a yamaha ....you won't be disappointed. mine is everything i could ever want in a reciever. also think about a seperate amp.
    Yamaha RX-V2600
    Adcom GFA555 x 2 :D
    Yamaha CD685 cd changer
    Yamaha Dvd c950 dvd changer
    Polk RTi12 mains
    Polk CSi3 center
    Polk psw303
    Polk RTi6 (surround and surround back)
    Acoustic Research 12in 200 watt sub(8 years old and still hits hard:D)
    WindyWillys cooling fan (works great)
    Mitsubishi 52in big screen
    blue jeans cables
    AR interconnects
  • MADGSF
    MADGSF Posts: 603
    edited May 2007
    Is there a "night mode" that might be enabled. Have you checked the dB level with a meter to see what the volume level really is? If not it couldn't hurt to set the channel levels as well.
    AVR: Elite VSX-21TXH
    Amplifier: B&K 7250 Series ii
    Misc: Velodyne SMS-1
    Mains: RTi-10
    Center: CSi-5
    Rear: Boston DSi460
    Sub: SVS PC-Ultra
    TV: Panasonic TC-P58V10
    DVD: Panasonic DMP-BD60K
