DB104 in a vented box...
Chumley
...are they designed for them? I have two DB104's in a vented box being pushed by a 200w x 2 Kicker amp...and they sound kinda distorted. Overall they sound well, but whenever they play a kick drum they produce a "thud" sound instead of the traditional "boom." Bass notes sound well, just the kick drums sound crappy. At first I was thinking they might needed to be broken in, but it's been almost 3 weeks with them being played every day at least a hour...so I don't know. Are they really made for sealed enclosures, or am I not running a strong enough sub/amp for the vented box? Thanks in advance!
Post edited by Chumley on
Hey! Who are you?!
I didnt think they let you post here anymore!
As for the question - could be a couple things.
1- you may need a little more power. Kick drums need a lot of juice to reproduce the actual impact.
2- your ported box could be tuned to the wrong frequency.
Follow the diagram in the link Kim gave you and see if that works.
However, I recommend looking into going with a sealed box. They just always seem to sound better IMO.polkaudio sound quality competitor since 2005
What box dimensions would you use if you wanted to build a "home" model SR subwoofer?Vinyl, the final frontier...
You could stick with the recommended specs. But if you wanted the flattest response, you can use the T/S parameters and this calculator to find the size.polkaudio sound quality competitor since 2005
