Question for vinyl fans.
ESavinon
If you had $3000.00 to spend on a turntable which table/stylus combo would you get?
I'm currently looking at a VPI scoutmaster signature and a Rega p5 with mods.
I'm partial to linear tracking turntables but have not found any new tables in this price range. Any recommendations on table/stylus combos will be appreciated.
SRT For Life; SDA Forever!
The SRT SEISMIC System:
Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once.
Post edited by ESavinon on
Different company philosophies there, but each make excellent tables, you are looking at new at that price??
I use ClearAudio Aurum Beta S on my Rega P-25 which is the same thing as the P-5, its an excellent cartridge for this table, I will be moving soon to either the Virtuoso or Maestro, both are MM, very lush rounded sounding.
I have heard the Scout with the Dynavector 380.00 cartridge (Troy's) every bit as good as the Rega and to some I am sure better, that Dynavector can track like nobody's business.
I don't know what upgrade your getting on the Rega, I have changed, my subplatter, platter and added Joe's clamp, sounds great.
RT1 -
After having looked at my options for my Scout, I would suggest the single plinth (Scout) with the Signature arm and the new Super Platter. I had thought of getting a ScoutMaster (probably the one you are looking at on Agon) and selling my Scout. I decided after reading as well as talking to VPI to use my funds to 'upgrade' to the Signature tonearm and the new platter. This should provide better results than having a double plinth (ScoutMaster).
The Dynavector 10x5 is a great cartridge and would be an excellent start. As for myself, I have moved on to a ZYX R-100FX(H)-SB cartridge for the Scout. This was a significant upgrade to the sonic characteristics.
Good luck.All truth passes through three stages. First, it is ridiculed, second it is violently opposed and third, it is accepted as self evident. -
Thanks jm1.SRT For Life; SDA Forever!
Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once. -
Talk to joe. I am heading down there today to pick up his VPI to bring home with me. (CANT WAIT)
I auditioned many tables befor maknig my choice. It came down to the VPI Scout and Rega P5 with rega Exact cartridge and optional TTPSU. The Rega won out. I found the music to be more natural with the Rega, although the VPI is a great table. My ears told me Rega.[
I would recommend checking out the offerings from Clearaudio, Pro-Ject, and JA Michell as well.
Keep in mind the expense of a good phono preamp. You don't want to blow your budget on a nice turntable just to limit it's abilities with a sub-par phono pre. (like I did)
I would also suggest putting some money into a good record cleaner.HT
Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
2 CH
Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500, -
I bought the krell ksa from carl just for analog.
I currently have a denon dp-59l with a shure v15 type v.
I'd like to upgrade to a vpi,rega or a pro-ject but so far i've not made up my mind yet.SRT For Life; SDA Forever!
