Balanced to unbalanced
ben62670
If a pre can put out up to 9 volts balanced, and is converted to unbalanced does the unbalance signal still have the same voltage as the balanced? I will be driving 3 amps with a combined 16k ohm input. The pre is rated at 10 K balanced.
Thanks Ben
Thanks Ben
Ben
Ben
Got a link to more info? I've seen balanced outputs rated both as the ground to + (or -) potential and as the + to - potential. In the latter case the unbalanced output would be half the balanced. This is why amps that have a sensitivity switch usually label the one with the lower gain "balanced"Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
On the amp or on the pre
Thanks UNC
The pre claims a max out of 9 volts. They do not specify balanced or unbalanced outs.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
You should shoot Outlaw an email brother.Shoot the jumper.....................BALLIN.............!!!!!
I will do that in the morning. Steve is very helpful, and I hope there is a simple solution. I am sure with more sensative amps this unit would fair better. All my adcoms have 50k inputs, and require up to 2 volts to operate properly.
Thanks BenPlease. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben
