1080p upscaling receivers
blacklab
blacklab Posts: 37
edited May 2007 in Electronics
If a new receiver upscales to 1080p, then is it necessary to subscribe to HD TV, get a BR or HD DVD player, etc... The logical answer to me is "no, because that is what you are paying for when you get an upscaling 1080p receiver". So, what are the thoughts out there?
  • AndyGwis
    AndyGwis Posts: 3,655
    edited May 2007
    Upscaling is nothing but the redheaded stepchild to HD content. It tries to make crappy content better than it is, but doesn't work 100%.
    Kind of like in Jurassic Park where they have some DNA code for Dinosaurs but fill in the gaps with frog DNA. Or, Superman where Richard Prior doesn't know the last ingredient for Kryptonite so he goes with Tar. I think we all know how both of those ordeals worked out. . . very poorly.
    In closing, 1080i/p upscaling is better than straight 480i/p, but HD TV, BR, and HD-DVD still blow it away.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • doggie750
    doggie750 Posts: 1,172
    edited May 2007
    AndyGwis wrote: »
    I had the same question as you b4.........upscaling market is misleading....stay away from it........get a ps3!
    Godspeed,
    D0661E
    AVR:Pioneer Elite SC-07
    Surrounds: RTis
    2channel:Rti100 (carver driven
    Sub:SVS PB12-Plus/2
    Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
    Wsrn:Hitachi ultra vision LCD60, 32XBR400
    PowerConditioner: MonsterC HTS5100
    PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
    MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
    Odyclub; Xsimulator; Sony; Zune; Canon
  • Spacedeckman
    Spacedeckman Posts: 96
    edited May 2007
    There is good upscaling, and bad upscaling. Good upscaling is expensive. Real 1080p would be better than upscaling. Don't hold your breath.
    Mark
    System:
    VPI Scout/Benz Ace
    Sutherland PH2000
    Arcam CD72
    Yamaha DVD-CX1 (primarily for CD..26 lbs, all BB D/A)
    Audioprism Mantissa w/Reference PS
    Parasound HCA750 (temporary)
    Audiovector M1 Signatures
    Kimber 4TC x 2
  • krabby5
    krabby5 Posts: 923
    edited May 2007
    blacklab wrote: »
    by that logic, you wouldn't even need the upscaling receiver..your tv upscales to it's native resolution anyways
    Which comes back to the upscaling dvd player debate..some see benefits, some don't..
    For me, I didn't see ANY improvement going from a 3 year-old 480i dvd player ($80) using component to a Denon 1930ci player ($350) using HDMI
    Pioneer Elite VSX-53, Polk RT800i fronts, Polk CS400i center, FX500i surround, Velodyne sub
  • John K.
    John K. Posts: 822
    edited May 2007
    Blacky, keep in mind what some have mentioned: "upscaling" makes lower resolution material playable on fixed "native resolution" HDTVs(not CRTs), but doesn't create "real" resolution, although the result on a new TV can look pretty good. Since displays having a fixed number of pixels(picture elements)on the screen have to fill all of them to even show a complete picture, 480 material from standard DVDs or standard definition TV has to have more pixels mathematically calculated and interpolated into the screen for 720 or 1080 displays. All such displays have to upscale lower definition material themselves if a player, separate processor or receiver hasn't already done it; the question would be if any of these units would do a visibly better job of scaling(or deinterlacing i to p)than the display itself would do. There are many displays which handle scaling and deinterlacing very well and in those cases this processing is superfluous in other units.
  • scottdwagner
    scottdwagner Posts: 106
    edited May 2007
    If you have an expensive video source with a good scaler, use it preferentially. If you have an expensive display with a good scaler, use it preferentially. If you have an expensive display and and an expensive video source, you're in better shape than me...
    Monitor Audio GR 60, GR10, GRLCR
    Velodyne HGS18
    Emotiva MMC-1
    Parasound Model 5250
    Denon DVD-3800
    Pioneer pdp-5070
    Secondary HT with B&W CDM-NTs all around and Rotel Separates (thanks Venom!)
