onkyo 604 & psw110
Yet another repetitive question... I have the sub cable connected to my sub pre-out on my avr and then Y'd off into the line level inputs instead of into the LFE. I noticed it seems more responsive this way but do I need put the crossover to 160 and adjust the phase to 180? This is the part where I get a lil bit lost. I used the Audessy calibration and it set all the speakers to large etc. Thanx! I guess if we all weren't so anal we wouldn't have good sound! lol!!
AVR: Onkyo TX-SR604/s
Front: Polk Rt1000i
Center: Polk CS400i
Surround: Polk FX500i
Subwoofer: Polk PSW110
Post edited by bionicmushroom on
  • cnjvh
    cnjvh Posts: 253
    edited May 2007
    Suggested and widely accepted setup:
    1. Set the speaker size in the AVR to small (even though the auto thing said large).
    2. Set the crossover in the AVR to 80.
    3. Leave the speaker distances set to whatever the AVR set them to during setup.
    4. Connect the sub cable into the LFE input, not the L+R inputs.
    5. Use an SPL meter to balance all speaker levels and the sub to 75dB with the master volume set at 0.
    6. Tweak to taste.
    The LFE input on the sub bypasses the sub's crossover and assumes the crossover is being handled by the AVR. The L+R inputs run through the subs crossover. this can lead to problems if a crossover is also being done in the AVR.
    If you're intent on leaving the speakers set to large, then use the l+r input on the sub (since the AVR's crossover is bypassed when speakers are set to large) and set the crossover on the sub to the -3dB point of the main speakers response. You will also have to set the subwoofer setting in the AVR to LFE+MAIN or the sub won't ever receive any signal at all for sources that dont contain a .1 channel.
    I use and recommend the first setup.
    No earth robot is going to tell ME which button to press!!
    --Stuff--
    Front: Polk Audio RTi12
    Center: Polk Audio CSi5
    Surrounds: Polk Audio RTi8 (x4)
    Sub: SVS PB10-ISD (Dual)
    AVR: Denon AVR-3805
    Blu-Ray: Panasonic BD30
    Display: Sony KDL-55NX720B
    STB: Xfinity X1DVR
  • engtaz
    engtaz Posts: 7,671
    edited May 2007
    well put.
    I would also play with the sub at 100 and 120 to see how it sounds to you.
    Do small on speakers your sub will do a better job with the LF.
    engtaz
  • bionicmushroom
    bionicmushroom Posts: 73
    edited May 2007
    For the speaker selection it says either "full-band" or you can select the "hz". What would be the proper "hz"? Maybe around 120hz? This is the worst part for me..I never got into all the hz, db's , etc..lol. I appreciate it guyz!
    Front: Polk Rt1000i
    Center: Polk CS400i
  • cnjvh
    cnjvh Posts: 253
    edited May 2007
    I presume this means you can set the crossover in your AVR for every speaker. The proper starting point would be 80hz for each speaker. Remember after setting this to move the sub cable from the l+r inputs to the LFE input.
    --Stuff--
    AVR: Denon AVR-3805
    STB: Xfinity X1DVR
  • engtaz
    engtaz Posts: 7,671
    edited May 2007
    Set each speaker to full range and small then change sub freq. to 80 hz then 100 hz then 120 hz and so on.to see what sound best to you. Page 67 starts manual speaker setup.
    From your manual pg 68 #9
    9. Use the Up and Down [ ]/[ ]
    buttons to select “g. LPFofLFE,”
    and then use the Left and Right
    [ ]/[ ] buttons to select a lowpass
    filter frequency.
    The following low-pass filter frequencies
    can be selected: 80 Hz, 100 Hz,
    120 Hz (default), 150 Hz, or 200 Hz.
    Continue with step 10 below.
    Hope this helps
    engtaz
  • Systems
    Systems Posts: 14,872
    edited June 2007
    Ive been looking for this kind of info on my sub for some time. I cant wait to get home and tweek. I might have some questions though :)
    Testing
    Testing
    Testing
  • auto_pilot
    auto_pilot Posts: 256
    edited June 2007
    If you set the sub to 80HZ...does that mean more lows will come out of the front left and right??? Mine is set to 100HZ.
    Cambridge Audio AZUR 640R
    KEF IQ2C Center, Fronts KEF IQ1 , Rears KEF Ci302Q
    Sub Outlaw LFM2
    Panasonic Plasma 1080i (50u)
    Sony DVP-NS70H (DVD)
    Belkin Pure Audio PF31 Line Conditioner
  • Serendipity
    Serendipity Posts: 6,975
    edited June 2007
    auto_pilot wrote: »
    Yes, but...
    Depends on your left and right speakers, placement, and many other factors. I would try 80Hz first and see how well the transition is from the 70Hz-100Hz range, and then try the 100Hz setting to see which blends better.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
