Biwiring
sageleo
sageleo Posts: 170
Advantages of biwiring as opposed to making jumpers from quality wire or is there no noticable difference?
T.V.- Sony KDL50W800B
Blu Ray- Custom built HT PC
Vizio Sound bar- S4221W
Post edited by sageleo on
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited May 2007
    sageleo wrote: »
    You may or may not notice a difference between higher quality jumpers or biwire but either should be better than just stock jumpers. I biwire my VR4 Jrs as opposed to using the datalink jumper they came with and the sound is way better. It all depends.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • engtaz
    engtaz Posts: 7,674
    edited May 2007
    wingnut is great (Bday and helping others = Priceless)
    engtaz
