What is the best reciever to go witht he polk RTi10
1lakerfan
1lakerfan Posts: 112
edited May 2007 in Speakers
which one? (no more than $2000)
Post edited by 1lakerfan on
  • swegyptian
    swegyptian Posts: 316
    edited May 2007
    What else do you need that unit to do? Any swtiching, or other stuff that is important?
  • BigA524
    BigA524 Posts: 63
    edited May 2007
    I just bought some with a onkyo TX-SR804..but had to return the receiver because the speakers were crackling..i guess some sort of internal problem..I think..great reciever though..
    Marantz 1607 - Polk S60 - S35 - Emotiva XPA-3 - Polk DSWPRO550wi
  • cfrizz
    cfrizz Posts: 13,415
    edited May 2007
    Find & listen to receivers that have all of the features you want it to have, making sure it has preouts for separate amplification down the road.
    Most on here find the pairing of Yamaha & RTI's to be a harsh combo. Otherwise, just take music you are very comfortable with & have fun comparing.
    Also for that kind of money, you might want to consider separates.
  • Monster Jam
    Monster Jam Posts: 919
    edited May 2007
    I agree...for $2000, you can do a lot with it.
    While I agree with going seperates, I think my methodology might differ from cfrizz and others here.
    Most will tell you that components generally offer better sound quality through improved amplification. I wont argue against that assertion. I look at that as an added bonus.
    What I champion is the adoption of seperates to stave obsoletion. I have a n HK AVR 525. Its nice, sounds good, all that. But as time passes, the features it supports dwindle. For example, it has no HDMI. What do I do? Buy another receiver and replace it in another 4 years? I think if you go components, the amp you buy (almost) never gets replaced unless the unit fails or you upgrade (amps have excellent resale value - you cant give an old receiver away however). All you replace is the pre-processor, or the receiver or using as a pre-processor. And if your using this strategy, your getting into the cheepest receiver you can that offers the bells and whistles you need.
    Just my 2 cents.
    Do you hear that buzzing noise? :confused:
  • aaharvel
    aaharvel Posts: 4,489
    edited May 2007
    Separates only - at least 200wpc - anything else will sound horrible.
    Seriously though, look into brands like NAD, Adcom, Outlaw, B&K. The 10's are more power hungry than the 8's, and you'll appreciate the extra current and honest power ratings (and firmware updates) those companies provide.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • engtaz
    engtaz Posts: 7,669
    edited May 2007
    aaharvel wrote: »
    Some of the best advice you will get.
    engtaz
  • m00npie
    m00npie Posts: 697
    edited May 2007
    I ran my 10's for a few months with my Denon 4306 and was pleased with it. I later added an Outlaw to drive them and it certainly helped them especially at higher listening levels in both Music and HT. The biggest difference between the Denon and the amp driving the 10's was Bass! After hooking them up to an amp, I never realized how much bass they could produce.
    Good luck!
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited May 2007
    How you figure? I ran mine on a 50wpc tube amp for critical listening in the cave - loud, clear, clean.
    Now they are in one of the living areas of the whole house rig, on 90w of HK power, and while not as refined, they still sound great.
    Cheers,
    Russ
  • m00npie
    m00npie Posts: 697
    edited May 2007
    RuSsMaN wrote: »
    Cheers,
    Russ
    RUSSMAN, was that directed at me or aaharvel? Since I didn't mention wpc I assume you were questioning aaharvel.
  • RuSsMaN
    edited May 2007
    It was directed at Pat Boone.
    Just speaking outloud, nothing to get wrapped up around the axle about.
    Cheers,
    Russ
