Parasound amps
sjt
Does anyone have any thoughts on adding a parasound 5125 power amp to a Denon Avr-2807 receiver. I have the Rti12's for my fronts, Csi5 for center and 2 pairs of Fxi3's for surround and surround back. I am just wondering if that would make a significant difference in the overall performance of my system
Post edited by sjt on
Your 12’s would appreciate the external amplification, I’m sure you will notice an improvement in two channel listening, if your looking for better performance HT wise, you should consider external amplification for the center channel also, let the Denon handle the surrounds.
If you have found a good deal on the amp, I’d say go for it, give it a listen and judge with your own ears.
Parasounds have a good rep. , you should have no problem re-selling it should it not give you the results your looking for.
Rock on.
GHT:
Martin Logan Motion 40
Martin Logan Motion 50XT
Emotiva Airmotiv E2
SVS SB16 Ultra
Def Tech Reference Sub
Yamaha RX-A3070
Signal Cable speaker wires & interconnects. -
My second go at separate amplification came from a Parasound 1500A 205wpc 2 channel amp. I loved it so my I now have all 5 of my channels amped!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
