Cheap monitor 5B X-over replacement
Jockos
Jockos Posts: 310
edited May 2007 in DIY, Mods & Tweaks
I finally got around to redoing my monitor 5B crossovers today. I went the inexpensive route with Dayton electrolytic audio caps and dayton 10w audio resistor. I found that one x-over had a cracked circuit trace under the cap. I used a left over piece of cap. lead to bridge it. Also the new 10w resistors were much taller so I also used a excess leftover capacitor leads .
After doing some intial listening there is definitely improvement. The highs are smoother with no grittiness. The orginal caps were 50v compared to the new 100v. Some pictures included.
Will now think about my RTA 11t's with solens or other quality caps.
The pics with the blue and purple caos are the originals and the blacks are the new ones.
Post edited by Jockos on
  • ben62670
    ben62670 Posts: 15,969
    edited May 2007
    Are those the cheap dayton caps that are less than $5 each. I need to do a project with 400uf caps, and the solens are out of my budget for now.
    Thanks Ben
    Ben
  • Jockos
    Jockos Posts: 310
    edited May 2007
    Yes, they're labled as high quality bipolar caps. The 33uf's were around $1. So far my speakers sound much better, more definition and smoother.
    Jockos
  • ben62670
    edited May 2007
    Jockos wrote: »
    Jockos
    Thanks Jacos. I was looking a using the cheap caps for such large values until I could come up with th coin to go solens.
    Ben
    Ben
  • engtaz
    engtaz Posts: 7,671
    edited May 2007
    Don't forget to give us your review of the audio changes.
    engtaz
  • george daniel
    george daniel Posts: 12,096
    edited May 2007
    here's a couple pics from my 5a's, solen,,mills,, vampire bp-hx connectors,,,,relatively simple job.
  • engtaz
    engtaz Posts: 7,671
    edited May 2007
    george is this Who's got the biggest CAPS LOL
    engtaz
  • george daniel
    edited May 2007
    current project,,these sre sonicaps
