Lsi 7
sageleo
sageleo Posts: 170
edited May 2007 in Speakers
I'm thinking of buy a pair of lsi 7's, but I have a few questions, are they good for home theater, and would my h/k 245 be able to push them or would I better off looking for something else?
T.V.- Sony KDL50W800B
Blu Ray- Custom built HT PC
Vizio Sound bar- S4221W
Post edited by sageleo on
  • G-2
    G-2 Posts: 533
    edited May 2007
    Welcome, the LSi7's are great speakers, I don't know much about h/k but you can always add an amp if needed.
    Chane
    A3rx-c's, A2rc-c, A1rx-c's|Miller & Kreisel V-125's|Sony XBR65X810C 65" 4K LED TV|
    Earthquake Cinenova Grande-5|Pioneer Elite - VSX-84TXSi-AVR|TRIPPLITE LCR2400|
    Ultrasonic Amp Stand|Blue Jeans,Audioquest,Monster Cables|
    2 - Channel
    Polk
    RTA 12c's w/RDO194 TWEETS, clarity ESA caps mills resistors (full mod)|Turntable|
    Anthem MCA 2|Acurus Act 3 Pre Pro|Parasound P/Ph 100|Pioneer Elite N-30|Adcom GDA600|
    Premier Rack|Blue Jeans,Audioquest,Monster Cables|
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited May 2007
    The H'K 'will' drive them, but not to their full potential. You could always grab the speakers for now and upgrade to a better amp later down the road.
    The LSi7 is a fantastic speaker, and will serve well in any application (music/HT)
  • PSOVLSK
    PSOVLSK Posts: 5,231
    edited May 2007
    +1 to the previous posts.
  • engtaz
    engtaz Posts: 7,664
    edited May 2007
    Output wattage: 7 x 50 watts
    Stereo wattage per channel: 50 watts per channel
    Surround sound: Yes
    Built in decoders: Dolby Pro Logic II and II, Dolby Digital, DTS
    Impedence: Audio: 100mV/47k; video: 1Vp-p/75 ohms
    Audio inputs: Front, center, surround, surround back, subwoofer
    A/V inputs: Component (Y, Pb, Pr), composite, S-video, HDMI
    Digital audio inputs: Coaxial, optical
    Outputs: 7.1 channel
    Signal to noise ratio: 100 dB
    those are 4 ohm speakers I can't find if your HT can support 4 ohm speakers.
    you do have pre amp outs so you could add a 200 watt external amp that supports 4 ohm speakers
    engtaz
  • Bill Ayotte
    Bill Ayotte Posts: 1,860
    edited May 2007
    From what I have read here, these are far more forgiving in terms of driving them with an AVR as compared to the LSi9.....I would pick them up now, and make my next upgrade an external amp or a high current receiver of some kind..Such as a NAD unit or a Sunfire Ultimate Receiver II...That Sunfire is on the extreme end of the AVR spectrum, it is basically a Theater Grand Pre/Pro with a 200w/7ch. amp built in...It puts out 400w/7ch. @4ohms.....
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited May 2007
    You will really like the LSI 7, it is an award winning speaker, these boxes can fill a room with sound, you can also buy the rti6 so now you have two pair of high quality speakers, everyone needs two pairs of speakers minimun, kinda like needing a fork and spoon.
    For sure the H&K will power the rti line, she is going to heat up some with Lsi.
    RT1
  • ohskigod
    ohskigod Posts: 6,502
    edited May 2007
    if you have pre outs, even some cheap used seperate amplification will get the job done. not too much more of an investment, wether you do it now or in the near future.
    if you run the 7's off the reciever, keep that bad boy where it can breathe.
    Living Room 2 Channel -
    Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
    Upstairs 2 Channel Rig -
    Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
    Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites
  • Yashu
    Yashu Posts: 772
    edited May 2007
    "everyone needs two pairs of speakers minimun, kinda like needing a fork and spoon."
    I have had a hard time explaining that to my girl...
    The LSi 7s are good speakers, but here is an important question: What are you going to use them for mostly... I mean do you listen to music more than HT? If music, what do you use for playing your music... CD, PC, Vinyl? It;s important to know.
    If you are going to listen to 75% music and 25% HT, I would do everything you could to find a better amp or receiver. If you use HT 75% and music 25% then you might be ok with just adding a seperate amp to the pre out on your receiver, or even consider different speakers. The LSi have more to offer for music listeners than HT, RTi have more to offer for HT than music.
  • mike65
    mike65 Posts: 2
    edited May 2007
    engtaz wrote: »
    Surround sound: Yes
    I just purchased the LSi7s 4 days ago from Tweeter (closing out sale) and from what I am reading here, these are power hungry speakers. I am also looking for an AVR to drive these speakers and was wondering why a 4ohm speaker is harder to drive than an 8ohm speaker? 4ohm means less resistance to current thus a receiver with specs: 110 watts @ 8ohms (Pioneer VSX-816K or VSX-917V-K) should be able to drive the LSi7s to its full potential correct?
  • reeltrouble1
    edited May 2007
    Down and dirty.
    Because the speaker resistance is less more current flows, the receiver cannot keep up, heats up, clips and eventually damages the speakers and its power supplies/circuits. Some receivers just shut down.
    RT1
  • McLoki
    McLoki Posts: 5,231
    edited May 2007
    The 7's will run fine from your HK. Like the rest of the LSi line, they will pay benefits with improved source or amplification, but the 7's are some of the few LSi speakers that will run ok from an AVR.
    I had 7's all around in my HT (now using them just as rear speakers) and they were great. I have a large room and stepped up to the 15's. (Also got the 15's because I like towers...)
    Give it a listen and decide for yourself....
    Michael
  • mike65
    mike65 Posts: 2
    edited May 2007
    Down and dirty.
    RT1
    That makes sense. Thanks for the clarification. I will now have to decide if I want to sell these or get the RTis instead to build my HT audio.
