Subwoofer Recommendation
Right now my current setup is cs1, monitor 40's, and monitor 30's in the rear with a velodyne vrp1000, I like the velo but I don't think its doing it for me does anyone have any recommendations that would go good with my current setup?
T.V.- Sony KDL50W800B
Blu Ray- Custom built HT PC
Vizio Sound bar- S4221W
Post edited by sageleo on
You could always check out SVS subs, www.svsound.com, they have awesome subs that will rattle your room.Shoot the jumper.....................BALLIN.............!!!!!
Do a search on here. this question gets asked at least once a month.
HSU and SVS are always good.Michael
Samsung 50" HD DLP
Yamaha RX-V2500
(2) Outlaw 200
Adcom GFA 555
Sony BDP300
Denon 2900 DVD
Lsi9's mains
Lsi7's rear
Lsic center
12.1 SVS driver in 4.53 cuft. tube
Harmony 880 -
SVS http://www.svsound.com/ check 'em out!Home Theater
Chane A3rx-c's, A2rc-c, A1rx-c's|Miller & Kreisel V-125's|Sony XBR65X810C 65" 4K LED TV|
Earthquake Cinenova Grande-5|Pioneer Elite - VSX-84TXSi-AVR|TRIPPLITE LCR2400|
Ultrasonic Amp Stand|Blue Jeans,Audioquest,Monster Cables|
2 - Channel
Polk RTA 12c's w/RDO194 TWEETS, clarity ESA caps mills resistors (full mod)|Turntable|
Anthem MCA 2|Acurus Act 3 Pre Pro|Parasound P/Ph 100|Pioneer Elite N-30|Adcom GDA600|
Premier Rack|Blue Jeans,Audioquest,Monster Cables| -
Not doing what for you??? The sub that is.
RT1 -
reeltrouble1 wrote: »Not doing what for you??? The sub that is.
RT1
I feel as though it is lacking in deep bass and distorts to easily, since I have bought it I have moved and the area where I use it substantially bigger then my old house I'm not sure if that has anything to do with it but I imagine it would.T.V.- Sony KDL50W800B
Vizio Sound bar- S4221W -
well, you can buy another bigger sub that will push more air and play louder or you can buy one like you have and stack them, stacking has advantages and you can get a 6db booste by corner loading the stack over twice as loud.
Subs are not that easy to lug around, there is an old trick where you put the sub in your listening position put on some bass tracks then crawl around on the floor (near the walls) and see where it sounds best. Then move the sub there.
RT1 -
Cool, interesting tweak.Michael
NORTH of 60°
