home theater suggestions requested
Danac787
Danac787 Posts: 18
edited May 2007 in Speakers
I am finishing my basement, I have recently purchased the following:
rti12 x2 fronts
csi5 center
psw505 sub
fxi5 sorrounds
amp is a yamaha rx-v2700
and a monster power unit as well
the question I have is:
is this sufficient? is 7.1 worth it? would I notice a difference? if so what 2 additional speakers would you recommend, and why? thanks in advance. I have spent a ton on this, I want it right, thanks.
Post edited by Danac787 on
  • bob1029
    bob1029 Posts: 20
    edited May 2007
    Personally I wouldnt bother with 7.1 unless room dimensions are really out there. A note about the rti-12s: You may want to purchase an additional pro amp such as the berhinger ep1500/2500 to power the lower section of your mains. I use a 2500 and it makes a HUGE difference over using just the reciever for power.
    Sharp Aquos 32d62u
    Onkyo TX-NR901
    Behringer EP2500 - RTi12 - CSi5 - FXi5
    Sonosub 700L tuned flat @ 14hZ
  • Schwingding
    Schwingding Posts: 363
    edited May 2007
    Agreed on all points with bob0129. You'll want/need more power to run those 12s effectively. 7.1 is a reach I don't find worth the bother.
    HT/music rig
    Panasonic PX60U 50" plasma
    Yamaha 5990 AVR
    Onix SP3 tube amp
    bunch of Outlaw 2200 monoblocks
    DUAL SVS PB12+/2 subs :eek:
    Denon 3910 DVD/SACD/DVD-A
    DirecTV HR10-250 DVR
    Onix Strata Mini mains
    Mirage OM10 surrounds
    Polk CSi5 center
    Polk SC80 rear surrounds
    Samsung BDP1000 blu-ray player
    Bedroom rig
    Jolida SJ302a tube amp
    Denon 2910 universal player
    Onix Ref 1 monitors
    Velodyne minivee
  • Sherardp
    Sherardp Posts: 8,038
    edited May 2007
    I would say depending on room size and placement. If you have the room size go for it(7.1), definitely amp those rti 12s up. You should check out Outlaw Audio, I went with the M2200 monos for the 12s, then just added another for my CSi5. I may add another 2 for my surrounds, they are good amps and sound well also.If you can swing it, go for a 5 or 7 channel.
    And last but not least, Welcome Aboard .
  • ohskigod
    ohskigod Posts: 6,502
    edited May 2007
    I can go 7.1 but just havent done it. to me, until more movies are specifically in that format, the juice will not be worth the squeeze. again, thats just my .02 and take nothing away from folks that got there 7.1 on :)
    Living Room 2 Channel -
    Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
    Upstairs 2 Channel Rig -
    Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
    Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites
  • cfrizz
    cfrizz Posts: 13,415
    edited May 2007
    Welcome Danac.
    Instead of going 7.1 you should invest in a separate amplifier of at least 200wpc. Make sure that it is one for Home theater equipment & not a pro-amp.
    If you can, get a 5 channel one & be done with it. It will save you from upgrading bit by bit. The amp will stay with you through all future upgrades.
    It will also make it easier to go to a separate prepro in the future since your amplification will be all set.
    Rotel, Parasound, Nad, Sunfire, Adcom, Outlaw are ones usually recommended around here.
    Keep an eye on our Flea Market, & also Audiogon for a good used one.
  • Danac787
    Danac787 Posts: 18
    edited May 2007
    thanks for the advice guys, I will take a look at an amp and hold off on 7.1 for now.
  • Shizelbs
    Shizelbs Posts: 7,433
    edited May 2007
    Get an extra amp for your mains (make sure your AVR has pre-outs) and why not go with 6.1?
  • Danac787
    Danac787 Posts: 18
    edited May 2007
    6.1 might be a viable option, how do you hook up the rear center? what outputs on the amp do you use for that? thanks. I know the amp has pre-amp outs for adding amps, and I know it can do 7.1 the amp I have is the current high end 7.1 from yamaha, there is only one step up i can make and that unit is almost 10k...so um that isnt going to happen :)
