Best way to hook up a sub
sageleo
sageleo Posts: 170
Now I'm just wondering because I have heard a few different things, I have heard that it is best to hook your sub up with the line level inputs, and I've also heard that it's best to hook up with sub pre out, which is best for HT and why?
T.V.- Sony KDL50W800B
Blu Ray- Custom built HT PC
Vizio Sound bar- S4221W
Post edited by sageleo on
  • kingkip
    kingkip Posts: 401
    edited May 2007
    Usually with the line level inputs. That way the LFE is from the media and the crossover is done in the preamp rather than by the sub itself. I think you'll find the vast majority of the folks around use the line level input.
    There are two ways to argue with women. Both of them are wrong.
  • engtaz
    engtaz Posts: 7,664
    edited May 2007
    sub pre out benifits is that Avr covers the cross over so you can change it a will instead of reaching behind it. Less wires.
    engtaz
  • Schwingding
    Schwingding Posts: 363
    edited May 2007
    I prefer the LFE for HT, line level for music only setups.
    HT/music rig
    Panasonic PX60U 50" plasma
    Yamaha 5990 AVR
    Onix SP3 tube amp
    bunch of Outlaw 2200 monoblocks
    DUAL SVS PB12+/2 subs :eek:
    Denon 3910 DVD/SACD/DVD-A
    DirecTV HR10-250 DVR
    Onix Strata Mini mains
    Mirage OM10 surrounds
    Polk CSi5 center
    Polk SC80 rear surrounds
    Samsung BDP1000 blu-ray player
    Bedroom rig
    Jolida SJ302a tube amp
    Denon 2910 universal player
    Onix Ref 1 monitors
    Velodyne minivee
  • northhillca
    northhillca Posts: 6
    edited May 2007
    Several ways to do it and keep in mind that the order of list below is not based on quality of sound.
    1. Line level pre-out to sub line level in and use sub crossover knob.
    2. LFE out from receiver to LFE in sub. Based on Polk website, for most polk subs, LFE is unfiltered. Set front speakers to large or preferably small if you have the heart.
    3. Set Front speakers to large and direct LFE to fronts, Connect AV fronts out to Sub "front in" and use sub cross over. Select sub "no" in receiver. Use sub "Front outs" to driver left and right speakers. (Polk recommended, I believe)
    4. Direct LFE/Bass info to both front and sub. Parallel wire front and sub from AV front out.
    5. If you dont have pre-out on receiver, connect LFE out to one of the line level inputs (red or white) and use sub crossover. Set receiver crossover frequency higher, say 200 Hz to mimick full range signal. Set front speakers as Large and LFE/Bass to both to cover the gap.
    You can be as creative as you like. You spent money to enjoy better sound. If you like an arrangement that is technically not perfect dont worry. Just enjoy.
  • liordra
    liordra Posts: 152
    edited May 2007
    If you use the LFE out, then you can set the fronts to SMALL. that would increase the over all volume of your system. your amp will not have to work so hard to push the power hungry lows (that's what the sub's amp is for) , and you will get better, cleaner power all across the range.
    But then again, The bottom line is that I keep changing my setup time and again. HiFi is a **** that way.
  • kocci
    kocci Posts: 2
    edited May 2007
    I also prefer the LFE for HT,is much better
