Need help with HDMI cable
MSALLA
MSALLA Posts: 1,602
edited May 2007 in Electronics
I want to switch the cable going from my HD box to the TV from component to hdmi. The problem is the hdmi port on the TV is bigger then the on on the Hd box. The TV is almost two years old and the Hd box is new from comcast. Please help guys.
Michael
Samsung 50" HD DLP
Yamaha RX-V2500
(2) Outlaw 200
Adcom GFA 555
Sony BDP300
Denon 2900 DVD
Lsi9's mains
Lsi7's rear
Lsic center
12.1 SVS driver in 4.53 cuft. tube
Harmony 880
Post edited by MSALLA on
  • krabby5
    krabby5 Posts: 923
    edited May 2007
    The HDMI input is bigger on the tv?
    I would assume they should all be the same size...regardless of age..
    hmmm
    someone else will probably know what you are talking about..:confused:
    Pioneer Elite VSX-53, Polk RT800i fronts, Polk CS400i center, FX500i surround, Velodyne sub
  • MSALLA
    MSALLA Posts: 1,602
    edited May 2007
    I know Nothin about HDMI. I have never used it and have been lazy about keeping up on the new versions so I am lost on it.
    Michael
    Samsung 50" HD DLP
    Yamaha RX-V2500
    (2) Outlaw 200
    Adcom GFA 555
    Sony BDP300
    Denon 2900 DVD
    Lsi9's mains
    Lsi7's rear
    Lsic center
    Harmony 880
  • BigA524
    BigA524 Posts: 63
    edited May 2007
    I have a tv about 2 years old and the slots are the same..thats wierd..
    Marantz 1607 - Polk S60 - S35 - Emotiva XPA-3 - Polk DSWPRO550wi
  • jflail2
    jflail2 Posts: 2,868
    edited May 2007
    Don't take this as insulting, but you're sure the slot on the tv is HDMI and not DVI? If that's the case this would work.
    My sony has a DVI, but no HDMI slot, so that was the 1st thing i thought of.
    Good luck!
    billbillw Posts: 7,468
    edited May 2007
    HDMI is a standard size that has not changed since inception.
    DVI is a completely different connection that is different in shape, size, and configuration.
    But, HDMI and DVI are pin compatible, which means they can be used together in most cases with an adaptor.
    Maybe this will shed some light and help you on your way to finding the correct cable (which I assume would be an HDMI to DVI cable)
    http://www.ramelectronics.net/html/howto-dvi-hdmi.html
  • Gaara
    Gaara Posts: 2,415
    edited May 2007
    If the slot is larger then HDMI then it probably isn't HDMI and could be RGB or DVI. RGB has 15 pins, DVI I can't remember but it has threads on either side to screw in and has pins and a metal piece that RGB doesn't...and it is more then 15 pins.
    Jared
  • MSALLA
    MSALLA Posts: 1,602
    edited May 2007
    I have used DVI before and they look nothing alike. (I am not insulted) I'm going to pull the TV out again to see if I was seeing things. From what you are all telling me I must be wrong. (happens sometimes)
    Michael
    Samsung 50" HD DLP
    Yamaha RX-V2500
    (2) Outlaw 200
    Adcom GFA 555
    Sony BDP300
    Denon 2900 DVD
    Lsi9's mains
    Lsi7's rear
    Lsic center
    Harmony 880
  • Gaara
    Gaara Posts: 2,415
    edited May 2007
    Samsung DLPs used DVI in the past before HDMI, and they also had a RGB and touted them as being able to be hooked up to a PC. If you know what a DVI looks like then I assume it is a RGB connection.
    The only other thing I can think of is a RS-232 connection or a USB, but I don't think the older units had the USB.
    If you know the model of the TV I could tell you exactly what it is.
    Jared
  • Sherardp
    Sherardp Posts: 8,038
    edited May 2007
    I agree with Jared, make sure its not a USB port, and take a pic if youre unsure, or of course you could post tv model so it can be researched.
  • jflail2
    edited May 2007
    The only other plug I can think of that could possibly be confused for an HDMI would be a firewire? That would look smaller than your normal HDMI plug though; and I've never seen a tv with a firewire port...
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited May 2007
    Can you post a picture of it?
    But I'm thinking Jflail2 is correct Firewire maybe? Or you could post the make and model of TV so someone could pulled to manual to help you out.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • Gaara
    Gaara Posts: 2,415
    edited May 2007
    There are sets with firewire but they are few and far between. I know Mitsubishi uses it to link components together with their netcommnad(?) system. but don't believe Samsung ever used it.
    edited May 2007
    My TV has firewire ports. It was common a couple years ago on sets that had internal tuners, TVGOS, and cable card slots. They have pretty much discontinued the use of them now though. However, I'm pretty sure that the firewire connections on most TV's are the mini sized ones that would be hard to be confuse with HDMI.
    MSALLA, if your HDTV is only 2-3 years old (assuming it wasn't a NOS model from more than 4 years ago) it should definitely have either DVI or HDMI. Check your owners manual or the manufacturers website.
