CSi5 tweeter is crackling. What to do??
My CSi5 is about 2 weeks old and recently I have noticed when high pitched vocals occur the CSi5's tweeter will make a scratchy/crackling noise along with the vocal. Also I will hear the noise when the characters say something which involves a lisp. My reciever is a 4 month old Denon 2307ci and I am using 12awg cables with banana clips.
View my Blog!
http://therubberband.tumblr.com/
Post edited by Speed3 on
If you have ruled everything out,you may need to replace the tweeter. DID you check/troubleshoot the connections and the receiver? Try another speaker on that channel,if the problem persists it's your receiver,if not,,may be the tweet,,good luckJC approves....he told me so. (F-1 nut)
Check the tweeter separately for functionality. I thought the same thing once, long ago, but it ended up being I just needed to clean up some dirty outputs from an older amp I was using.
Also, check connections, make sure it's calibrated correctly, etc.Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850 -
If it's a dirty/interference like sound, then it's a channel/connection or tweeter. If it's sibilance, then that's pretty much source dependent and part of the RTi line from my experience.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE
