WTB projector and ht seating
schwerhaiv
schwerhaiv Posts: 72
edited May 2007 in Wanted (WTB) Classifieds
I am looking to buy a projector for a home theater and home theater seating. Would prefer 720p projector that someone is upgrading to 1080p. New options are about $800.00, so please take that into account.
I am also looking to purchase new home theater seating. Probably two rows of four. Even advice on this topic is appreciated.
If someone has either, please contact me.
Post edited by schwerhaiv on
  • Sherardp
    Sherardp Posts: 8,038
    edited May 2007
    are you saying you only want to spend 800 bucks? Berkline seating should suffice, its very nice and comfy and can be found online for great prices. Check out the infocus IN76, Panasonic PT-AE1000U, Mitsubishi HD1000U,Panasonic PT-AX100U
  • schwerhaiv
    edited May 2007
    Yes, I mean 800 for the projector. if I were to buy in new. Right now I am looking real hard at the refurbished models. Especially the HD70.
  • scottdwagner
    scottdwagner Posts: 106
    edited May 2007
    Check out overstock if you're looking for something rather inexpensive for HT seating. They have 3 and 4 seaters for a reasonable price with cheap shipping:
    http://www.overstock.com/cgi-bin/d2.cgi?page=proframe&prod_id=1518604&IID=prod1518604
    http://www.overstock.com/cgi-bin/d2.cgi?page=proframe&prod_id=2089735&IID=prod2089735
    Monitor Audio GR 60, GR10, GRLCR
    Velodyne HGS18
    Emotiva MMC-1
    Parasound Model 5250
    Denon DVD-3800
    Pioneer pdp-5070
    Secondary HT with B&W CDM-NTs all around and Rotel Separates (thanks Venom!)
  • louthewiz
    louthewiz Posts: 581
    edited May 2007
    As for the projector you can check projector central for great deals on refurbs and overstock PJs and the used section usually has refurbs and open boxed deals..
    http://www.projectorcentral.com/
    here is the used page:
    http://www.projectorcentral.com/used_projectors.cfm?bll=any&bul=any&wll=any&wul=any&prll=any&prul=any&res_family_id=any&city=0&state=0&country=0&trig=1
    My gear,
    Acer PH530 720P PJ
    100 inch Da-Lite Video Spectra screen
    Yamaha HTR 5790
    Toshiba HD-A3
    Denon 1600 dvd player with sdi out,
    DVDO iSCAN HD+
    Panasonic Dmr E-80H
    Dishnetwork HD pvr
    1 Audiosource amp300 150 wpc Fronts
    1 Audiosource ampone bridged 200 watts powering center
    1 Onkyo M-282 105 wpc amplifier sides
    polk cs400 center
    polk RT400 mains
    Polk mkII back surrounds,
    Polk FX300fxi dipole surrounds
    Velodyne DPS-10 sub
    Klipsch KSW-10 sub.:cool:
  • hearingimpared
    hearingimpared Posts: 21,136
    edited May 2007
    A little advise on the projector. Make sure to buy a bulb warranty. One of the reasons, actually the reason that convinced me to purchase my particular projector is that is has a three year, three bulb warranty on it. One bulb for my projector costs $350 plus shipping. If you are going to do anything more than watch movies with your projector then you really really should consider this. My son has the same projector and he and his roommates use it for everything not just movies and he has been through two bulbs in less than two years. That's $700 just to watch TV.
  • louthewiz
    edited May 2007
    I am still on my first bulb since over a year with my powerlite 10 and the bulbs go for $149.oo and last 3,000 hours.
    My gear,
    Acer PH530 720P PJ
    Yamaha HTR 5790
    Toshiba HD-A3
    DVDO iSCAN HD+
    Panasonic Dmr E-80H
    Dishnetwork HD pvr
    polk cs400 center
    polk RT400 mains
    Velodyne DPS-10 sub
  • hearingimpared
    edited May 2007
    louthewiz wrote: »
    The bulbs that come with mine are 2 to 3 thousand hours. $149 is a good price. I guess your projector has new technology.
  • louthewiz
    edited May 2007
    This is the projector that I own , The specs are listed at the link below.
    http://www.projectorcentral.com/Epson-PowerLite_Home_10+.htm
    And this is where I purchased a replacement bulb which went up $10.00
    since I bought one around December,
    http://www.techonweb.com/products/productdetail.aspx?id=A54616&src=NT
    My gear,
    Acer PH530 720P PJ
    Yamaha HTR 5790
    Toshiba HD-A3
    DVDO iSCAN HD+
    Panasonic Dmr E-80H
    Dishnetwork HD pvr
    polk cs400 center
    polk RT400 mains
    Velodyne DPS-10 sub
  • ben62670
    ben62670 Posts: 15,969
    edited May 2007
    louthewiz wrote: »
    Lou suggested this projector to me, and I have been quite satisfied with it. I use mine all the time, and the bulbs are only $150 each(haven't killed one yet). The unit itself is only $384 new on ebay. The picture is 480 so don't expect a ton from it. The colors are real good. I project mine from about 14 feet, and the screen is about 8 feet. I watch from about 12 feet. DVDs are 480 anyways. So if you are not doing the HD thing yet it is a real deal to get started in projectors. When the prices come down on better projectors, and bulbs I will upgrade
    Ben
  • wallstreet
    wallstreet Posts: 1,405
    edited May 2007
    You could try avsforum. They usually have a good selection of folks upgrading to 1080p's looking to unload their 720p's. At $1K, you've got Optoma HD70 or Mits HD1000u.
  • engtaz
    engtaz Posts: 7,664
    edited May 2007
    I have and love my Mits HD1000U
    projectorpeople have it new with 3 year lamp warrenty for a tad over $1000.
    engtaz
  • wallstreet
    edited May 2007
    They've dropped the price on those to $995. I checked my wholesale price and it's $981. You know your wholesaler is sticking it to you when you can buy it retail for $14 more.
  • ben62670
    edited May 2007
    Check the price of bulbs before you buy!
    Ben
