Fuse help needed
vawakemonster
vawakemonster Posts: 131
edited May 2007 in Car Audio & Electronics
While driving downtown my speakers all went out. when I arived at my girlfriends I discovered the fuse ahd blown in my phoenix gold amp(25 amp fuse.)
each time it ried to replace it the fuse would arc or blow the second it touched or was inserted in the amp. I tried to take hte fuse out of my power line and put it in my amp btu the amp fuse blew the second the fuse was plaved back in the battery line.
I unplugged the speakers and the amp still blows a fuse. What should i do?
Dodge Dakota
HU: Pioneer
Amp: Profile AP600 & Phoenix gold r2.5:2
Speakers: Boston SX 6.5 components
Subwoofer: polk mm2104
Post edited by vawakemonster on
  • exalted512
    exalted512 Posts: 10,734
    edited May 2007
    So the fuse on your power wire is fine but the fuse on the amp keeps blowing? What size fuse do you have on the main power wire?
    -Cody
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited May 2007
    Bad amp? Shorted transistor?
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • PoweredByDodge
    PoweredByDodge Posts: 4,185
    edited May 2007
    no, what's happening is he unplugged the larger fuse on his main battery line, put the 25 amp back in the amplifier, then replaced the big one and the 25 popped again.
    ... 25 will blow first because it's smaller.
    IF -- IF -- the amplifier is blowing fuses while it is turned off, then it is likely that the power supply is shot (or the output is shot and it caused the power supply to go - more likely). IF it blows fuses ONLY when turned on, then the output stage is likely only blown.
    Either way, you're looking at a rebuild, which isn't cheap.
    The Artist formerly known as PoweredByDodge
  • vawakemonster
    edited May 2007
    see as Ive only had the amp for 5 weeks this rebuild is on phoenix gold
    Dodge Dakota
    HU: Pioneer
  • PoweredByDodge
    edited May 2007
    ... good -- 'cheap as free' is always a positive.
