LSi 15 2 channel set up
Polk & H/K
Best way to power LSi 15s fof 2 channel integrated amp or stereo receiver. Integrated amps Cambridge Audio 640A, Creek 5350SE or NAD C372. Stereo Receivers H/K 3480.
Post edited by Polk & H/K on
If you have the money for those receivers why not just go with separates?
LS15's require more power to perform well. Owners recommend 200 WPC@8 ohm minimum._________________________________________________
Can I use the H/K 3480 as the pre/pro & 2 Outlaw 2200s?
You can, but you won't be using the amp section of the HK. A Preamp might be a better purchase, unless you like that the HK has more features and a tuner.Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850 -
The H/K $249.
What do you already own? I 2nd HTrookieengtaz
get a nice Nad integrated amp
http://nadelectronics.com/products/hifi-amplifiers/C372-Stereo-Integrated-Amplifier/specs2 CHANNEL
Speaker - Klipsch Heresy II
Under construction -
I have the H/K 635, Polk RTi6s,R 15s, CSi3 & PSW 350.
2 CHANNEL
The NAD C327 is 2x150w in 4ohms 340 dynamic power will the LSi 15s perform well with the NAD?
Yeah those power ratings are very conservative2 CHANNEL
thats a little hostile
Just asking to find out if Polk & H/K already had a AVR. He answered and does and it has preamp outs sooooo he can go with external amps @ 200 watts a ch.engtaz
Unless you are going with a totally different 2-channel setup in a different room, Polk/HK, I would utilize what you already own. The 635 is a capable pre-pro, so just replace your current front with the LSI 15s, add a nice Parasounds, B&K, Rotel, Adcom, etc. amp for the fronts, and go to town.
Now, if it's a separate system, I would either go with a nice matching separates combo, or an integrated amp. I got a MF integrated and couldn't be happier. All the functionality I wanted, just as good of sound as my B&K gear (my favorite sounding gear), a very classy chassis, and a reasonable pricetag.Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Isn't this your THIRD thread asking what to power Lsi's with?:rolleyes:
I had the NAD C372 powering my LSI15's. It sounded thin and flat. Almost sold my 15's. Then I got a used adcom 555II, wow like night and day. The speakers came alive, not just at high volume levels but also at low settings. I currently am running a adcom gfa 5500.
Jockos -
I swear, he sounds just like PolkLSI/JoshParsons!:rolleyes: Once he wears out his welcome with one name he creates another & asks the same annoying questions all over again!Isn't this your THIRD thread asking what to power Lsi's with?:rolleyes:Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
