Critique my 2-channel rig
AndyGwis
AndyGwis Posts: 3,655
edited May 2007 in 2 Channel Audio
Hey Guys,
Just got some cool new gear put into my 2-channel rig. Here's the current set-up (I'll try to add some pics soon, but I broke a second LCD on my digital camera in 2 months):
2 Channel Rig: Work in Progress -
CD Playback: Sony SCD-C2000ES transport --> coaxial cable --> Theta Pro Progeny DAC --> Kimber PBJs --> Musical Fidelity A3.2 Integrated --> PS Audio XStream Plus cables --> Thiel CS 1.2s
SACD: Sony SCD-C2000ES --> Quake ICs --> MF integrated
Also, Marantz ST-6000 tuner, Monster HTS 5100 Signature Series, Senn HD-580 cans
Thoughts on next step? Might try out some SDAs next, but Thiels are doing admirable with newly rebuilt tweeter. Not even sure what my weakest link is right now. Would be the Source, but the DAC kind of nullifies that.
Thanks for your opinions!
Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
Post edited by AndyGwis on
  • Early B.
    Early B. Posts: 7,900
    edited May 2007
    Looks like a great system. The only advice I'd give is replace the PBJ's with Heros.
    "God grooves with tubes."
  • AndyGwis
    edited May 2007
    Speaking of Heros. . . You're my hero, Early. I hope you know that.
  • Ricardo
    Ricardo Posts: 10,636
    edited May 2007
    Ok; it stinks :eek: :eek: :D:D
    SOPA
  • Ricardo
    edited May 2007
    Looks great; I almost got a pair of Thiels. They surely are great speakers.
    SOPA
  • AndyGwis
    edited May 2007
    Well, I put critique cuz I was wanting more than just " great system," "way to go big guy," and all the other common reach-arounds handed out when someone puts up a "check out my sweet rig" type post.
    So, yes constructive criticism, but no snobby jackassery or pat on the back handjobedness, please :)
  • Ricardo
    edited May 2007
    Ok; it still stinks ;)
    Really, not much to critique; you have great speakers (sorry for using "great"), and good gear. The only think I would maybe recommend just to try something different is to get a tubed CD player in the game.
    SOPA
  • ohskigod
    ohskigod Posts: 6,502
    edited May 2007
    cant go too wrong with that rig. Thiels are always on my list for when I look around for used speakers to try. couple good deals popped, but I never jumped. shame on me, cause I'd love to hear em.
    rig seems pretty balanced, no glaring weak link to my eyes. if it sounds good, roll with it.
    Living Room 2 Channel -
    Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
    Upstairs 2 Channel Rig -
    Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
    Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites
  • AndyGwis
    edited May 2007
    Thanks for the comments. I was thinking of incorporating some tubage, even looked into the DK Designs hybrid integrated. But, when the MF popped up here from a trusted member at a great price, it was hard not to jump on it. Tube CDPs are great, too, but I wanted SACD capability and a headphone out with gain control from my player so I wouldn't have to have two players (redbook and SACD) and a headphone amp. Much more cost effective the way I have it now.
    My philosophy to this point has been "if it's an awesome deal, grab it." So, I went through A LOT of gear the past year and have narrowed it down to the "best of breed" in my price range with the functionality I need.
    BTW, if you saw the setup in person, you'd immediately tell me to get a real room for this stuff. Not as bad as the Martin Logan guy that hung his stats behind the couch in a 6' by 6' area, but not far from it.
  • steveinaz
    steveinaz Posts: 19,538
    edited May 2007
    Real nice Andy. I like it alot. Agree, if you're bored, pick-up a set of Hero's for the transport-->DAC connect. I had the PBJ's and the Hero just gives you a little more of what is already good about the PBJ; not sure that it's worth the extra coin though.
  • Ricardo
    edited May 2007
    I think you did right in getting a SS integrated; I've heard that Thiels don't go too well with tube amps, unless they are VERY high power.
    SOPA
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited May 2007
    Musical Fidelity makes better products than your present integrated, It is difficult to critique without a budget, but you will need to change the preamp/integrated. MF makes some great integrated amps with seperate power supplies, also I would look at seperates from BAT and Cary Audio as two suggestions, there are countless others. You will need to upgrade your cables as you move up the chain, what make/brand is an individual decision. Dump the monster, it is current limiting and at some point will limit the rig. I highly recommend the Shunyata.
    If you have never had a set of SDA by all means it is a speaker you should enjoy on your path. For some it is the end all. I would certainly recommend trying some Caver Amazings and Maggies along the way as well.
    RT1
  • hearingimpared
    hearingimpared Posts: 21,136
    edited May 2007
    WOW, I never heard a rig that sounded like that!!!
  • engtaz
    engtaz Posts: 7,664
    edited May 2007
    Nice setup
    engtaz
  • AndyGwis
    edited May 2007
    Well, I haven't bought anything at what I would call "market price." So, for a budget, you could say my rig at used market/street value is around $3K (cables, stand, and all). But, thanks to my thrifty nature, I doubt I've spent over $2K on the 2-channel gear I have running right now.
    So, the next step will probably cost me an arm and a leg if I were just to hit up Agon and snag some Cary separates or a better MF integrated. But, I'll put them on my radar and try to hopefully come across another great deal on something.
    I'm thinking power cords might be an okay idea. And, probably some new material/media to play. A TT is in my future before too long as the MF has a phono input.
  • rskarvan
    rskarvan Posts: 2,374
    edited May 2007
    SDA's would likely be taking a step downward. The Thiel's have a crispness to the sound that would be lacking in the SDA's. If I'd do anything... I'd step up the Thiel line to a higher end speaker.
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited May 2007
    I second upgrading to the Heros over the PBJs or ...You could go with DH Labs Air Matrix which I preferred over the Heros.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • Early B.
    edited May 2007
    Same here. I went from Heros to Air Matrix and it was a definite upgrade, IMO.
  • AndyGwis
    edited May 2007
    Quick Update - I got my Monster Power Center HTS 5100 Signature Series yesterday and plugged it into my 2-channel rig.
    Anyway, I know it may restrict some current, but I doubt I'm drawing that much in my little listening space. And, I know Monster is a rip-off at retail price. And, I'm generally not a fan of spending big money on things like power conditioners. . . but. . .
    This things was a steal of a deal from JB Audio Pimp, and is in pretty much like-new condition, and the blue lights match the blue lights of my MF integrated, and Theta DAC, and to a lesser degree Sony SCD player. Basically, it looks awesome, and helps in the "piece of mind" category. The power cable to this thing is THICK. Not sure I'm going to use the switched/delay capabilities at any point with this rig, but I'm really happy with the purchase.
  • NeilGabriel
    NeilGabriel Posts: 1,487
    edited May 2007
    How about, you could have fed a small 3rd world nation for what all that cost? Is that a critique? ok, where the hell is the smiley face?
  • AndyGwis
    edited May 2007
    Well, I was thinking of buying some food to send to third world countries, but the shipping charges were outrageous!!!
    I did put a dollar in the jar at the grocery store yesterday for a children with disabilities charity.
  • hearingimpared
    edited May 2007
    AndyGwis wrote: »
    I have a 5100 and although it may be current limiting I have haven't notice it holding back my rig as of yet and I push my amps and speakers pretty hard, a Shunyata is out of my league right now but when I get the funds allocated for power upgrading that is going to be one of the first things on the list. I have an electrician coming over in June to pull four 20 amp lines for the 2 ch rig.
  • Shizelbs
    Shizelbs Posts: 7,433
    edited May 2007
    I'd listen to it. I bet it rocks.
  • NeilGabriel
    edited May 2007
    AndyGwis wrote: »
    Next time, drop in a System of A Down cd for them. You know ridicule is just a disguise for jealousy!
  • JimBRICK
    JimBRICK Posts: 1,543
    edited May 2007
    All you need now is a good PHONO
    VINYL RULES
    2 CHANNEL
    Speaker - Klipsch Heresy II
    Under construction
  • AndyGwis
    edited May 2007
    TT is next. Got an integrated with a good Phono so I could try out some vinyl without too much hassle (cash).
    F1nut Posts: 50,731
    edited May 2007
    Get rid of the Kimber and PS cables, step up to MIT.
  • hearingimpared
    edited May 2007
    AndyGwis wrote: »
    You are speaking my language my good man!!!
  • JimBRICK
    edited May 2007
    I was listening to Johnny cash from folsom today actually, I love vinyl
    2 CHANNEL
    Under construction
  • hearingimpared
    edited May 2007
    JimBRICK wrote: »
    I love Johhny Cash to death!!!! Believe it or not I have none, nadda, squat, of his awesome recodings on vinyl. . .that is one of the few aberrations in my vinyl collection. I do have his CD boxed set and some best ofs . . . I want the real deal though.
