Banana plugs recommendation
at first i bought plugs from Tweeter.....don't remember the name. they were kind of loose on LSI 9s and Outlaw Amps. today i went to Home Depot and got GE plugs: they are excellent, and have a very tight fit. RECOMMEND
Post edited by kolyan2k on
Although expensive, I recommend the Eichmann Bayonet plugs....Easy to solder, and they have a nice, tight fit....
Altex has some great banana plugs. $4.29/pair and they are great.
I probably have 15 pairs.Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850 -
I have screw type from Monoprice, no complaints."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Altex look EXACTLY the same as GE ones that i bought at home depot for 6 something a pair
http://www.altex.com/product_info.php?cPath=3_106_330_331&products_id=4512 -
I have the solder on type but you don't have to solder.engtaz
I use the GLS locking banana plugs and I like them. Very reasonably priced.
