Well .... that's interesting ?!
mrbigbluelight
In an attempt to burn some educational mpg files to DVD, I've basically driven myself nuts.
I figured, "Somebody on Club Polk has had this problem before, brought it up on some thread, and I'll find my answer".
So far, so good.
So I bring up the Polk site, type in "burn DVD" in the "Search" window, and I get:
You answered the NoSpam! question incorrectly. Please reevaluate your answer or, if you found yourself unable to answer it, you can refresh for another question if the administrator has enabled multiple questions. If you find yourself repeatedly unable to answer the NoSpam! questions, please contact the forum administration.
So .... having already reached new heights of confusion using Roxio Creator 9, I've decided ...... I'm just going to ...... go sit in the corner for awhile .......
....and ...... wish myself into the corn.
So far, so good.
Post edited by mrbigbluelight on
Are you trying to copy files from your computer to DVD or copy an existing DVD?
I get the same nospam message, but only when not logged in. To my knowledge there is no way to answer the question correctly when you are not logged in (and it does not ask you the no spam question when you are logged in).
I do an advanced search in google and tell it to only return results from the domain polkaudio.com - it works quite well.
There are threads, try your search for "burn dvd" again.
