Want to add midbass.. will it ruin my sound?
dohcmark8
Hey all. I am looking to add a pair of midbass speakers. One in each front door. At the moment my setup is db525's in the dash and a db104 in the back.
Would adding midbass speakers in the door hurt my sound or help it? I just want more kick in the mids. Or would I be better off going for a bigger sub or maybe trying to fit bigger speakers in the dash?
I'm looking at the Image Dynamics mids.
Thanks.
edit: What if I were to add one mid and stick in the dash?
Thanks.
Post edited by dohcmark8 on
Dedicated midbass speakers can improve your sound quite a bit especially with only 5.25's in the dash where I doubt theyre making much midbass.
The downside will be needing an extra amp and theyre kind of a pain in the **** to get dialed in right. But once you get it tuned in, it does sound pretty good. I like 2 way setups myself but there are sometimes when you need a dedicated midbass speaker.polkaudio sound quality competitor since 2005
Thanks.
Would it be feasible to use just one midbass and stick it in center on the ground in the front? This is a minivan so space is a plenty down there.
Let me show you where: http://zebsadiq.googlepages.com/DSC02009.jpg
Excuse the mess there, it was taken during install. But I want to stick a midbass where those CDs are.
Any advice would be helpful. Thanks. -
It would be better to stick em in the doors.polkaudio sound quality competitor since 2005
Problem with that is my doors don't have a cutout for the speakers. So if I wanted to put anything in the doors I would have to locate the bracket for the front speakers and get new door panels. Only vans with the Infinity system had the brackets so I dont even know if I can get the part.
Would one midbass be workable though is what I'm wondering.
If not.. would a component set like the MMC5250 or something offer more midbass than the db525? I recently installed Dynamat in my front doors (one layer of Dynamat and one layer of Dynaliner) and Hoodliner in the hood so so my mids have improved, but I just want more. -
Nevermind. Got my answer.
Two mids in kickpanels. :-)
