Value of Smooth Power ?
Paul.Cox
Paul.Cox Posts: 12
edited April 2007 in 2 Channel Audio
Looking for comments on the value that power conditioners bring to a Hi Fi system. There would seem to be a number on offer like the Belkin PureAV series. Has anyone out there have exeprience in his area ?
Post edited by Paul.Cox on
  • AndyGwis
    AndyGwis Posts: 3,655
    edited April 2007
    I just bought a Monster Power Center HTS 5100. . . just for piece of mind, cable management, to fill up space on my rack, and for the cool lights. Not sure of the science behind it.
    I looked at Belkin PureAV as well. Snag a nice PF60 on ebay for like $150 - $200 if you like the looks. There are numerous good offerings from Furman, Panamax, etc. as well.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • Nisqually Dave
    Nisqually Dave Posts: 220
    edited April 2007
    But do they really make a difference
  • dkg999
    dkg999 Posts: 5,647
    edited April 2007
    Make a difference - yes! Whether you like that difference or not is something you will need to find out based on your scenario. In my apt building the power is really dirty and the wiring is pretty old. Using a Panamax on my 2 ch system and a Tripp Lite on my HT system did make a positive improvement. Less interference and quieter background. Both have high-current outlets for amplifiers. Well worth the investment in my case. Your mileage may vary.
    DKG999
  • WilliamM2
    WilliamM2 Posts: 4,807
    edited April 2007
    I have two, a Panamax and a Monster Power. Bought mine mainly for the switched outlets, so that I can turn everything on and off with one button on the remote. Surge protection is nice for piece of mind as well.
    Can't say it made any audible difference, but I have very stable power, and never had any problems with noise before I purchased them.
  • mulveling
    mulveling Posts: 505
    edited April 2007
    I use them (Monster 3500 MkII) mostly for these reasons:
    1) Peace of mind.
    2) Convenience (more outlets available)
    3) Hum/ground loop busting (by having all components on the same outlet)
    Though, #1 is typically moot since I end up unplugging everything after use...can never be too careful with expensive gear. I've compared the effect of the conditioning on high end headphone systems (up to $9K)...the sonic difference is small to negligible in my system, to my ears. I don't even run my new JC-1 monos out of the conditioner - just straight into the wall sockets, with the grounds lifted to prevent hum. They pull so much damn juice - 500 Watts idle, and more than what the 15amp line can supply at the max rated power. I want as little as possible in their path to the power, and those huge-**** caps in the power supply probably aren't just for the heck of it ;)
    Tannoy Dimension TD10, SOTA Star Sapphire, Heathkit W4A's, McIntosh MC2100, Eddie-Current Zana Deux, Singlepower SDS, Sennheiser HD650, Audio-Technica L3000, Sony Qualia 010
  • AndyGwis
    edited April 2007
    What's a good price point for a nice one? I'm thinking $200 can find you a plethora of nice (albeit used) power conditioners. That's what I paid for mine. Could've gotten a cheaper one, but they just didn't look as beefy (like the Adcom 515). I don't want something too scrawny if it's the POWER house of my system, and it has to look good on the stand/rack.
  • venomclan
    venomclan Posts: 2,467
    edited April 2007
    I use the Belkin PF60. The noticable improvement I saw initially was a brighter picture. I was using a PS2 and noticed that the colors were a bit less washed out through the Belkin. As far as sound-wise, tough call. I was told by Krell not run my amp through any conditioner as it may limit the power to the amp. The Belkin does have 2 high power outlets for amps I use it for. I hear no sound difference.
    I love the look of the Belkin, and the voltage and amp meters work great. I know that in the middle of the day, with my A/C and pool pump on, the voltage is at its lowest (116-119v). At 3 a.m. it is higher (124v).
    For me the unit payed for itself when I added a new piece of gear, a ground loop was coming in through the cable line. I ran the cable line throught the PF60 and solved the problem.
    V
    treitz3 Posts: 20,007
    edited April 2007
    Paul.Cox wrote: »
    In my experience, none. Nada. Pissed me off too because I blew 300 bills to get an improvement. [Monster HTS1500] I even returned that one with another new unit, same result. Nothing.
    I kept it because of the convenience factor with turning equipment on/off. Damnit. Video, different ball of wax.
  • Serendipity
    Serendipity Posts: 6,975
    edited April 2007
    treitz3 wrote: »
    IMO they make a difference, a power conditioner eliminated a slight hum from my system, and also cleared up my OTA reception.
    Just my opinion.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
    edited April 2007
    Lucky dog. That's the kind of thing I was looking forward too. Any change would have been good........soundstage difference, crisper bass, midbass, or vocals, quieter background, something, anything. Nope not a damn thing. Damnit.:mad: Oh well. Now a Richard Grey 400 pro power supply.....yeah baby! But that's a different subject.
    Oh, there was one change. When I hooked up my Polk PSW1000 to [or thru] it, the sound was severely hampered. The sub is now plugged into the wall with a nice power cord upgrade.
  • Paul.Cox
    Paul.Cox Posts: 12
    edited April 2007
    Thanks for the comments. It would seem the affect is related to the quality of the power. Am interested that it has solved some issues with speaker humm - I have a small humm from by speakers.
    cheers
  • Polk65
    Polk65 Posts: 1,405
    edited April 2007
    As hinted, power is also important. Consider changing a 15A circuit to 20A.
