Hk 3480
Polk & H/K
Will the HK 3480 power the Polk LSi 9s.
Post edited by Polk & H/K on
Yes.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
I used to have the Stereo receiver from H/K
I think it rated at 125 WPC high current bandwidth
Anyhow it is very powerful
Should be ok with that speakers -
When I first got my LSi9's I used the HK3480 to drive them. Unless you have huge amount of space you're trying to fill with sound they should do just fine.
