Connecting separates
NeilGabriel
NeilGabriel Posts: 1,487
edited April 2007 in Electronics
With the inspiration of some members here (and the recent settlement of a big case)....I am going separates for HT and just picked up a Rotel processor. Could someone please advise on the connections between preamp and amp. I am really just interested in the unbalanced connections. Are these simply single strand RCA cables with phono plugs, or different? I assume like all connections, there are huge differences in the quality that is available? I'd like to order something on line this evening. A friend buys all of his cabling off ebay and claims to get good value. Anybody else? Thanks. (sorry...this should have gone to hookups where there is some discussion of this already...I was multi-tasking and clicked wrong category).
Post edited by NeilGabriel on
  • Ricardo
    Ricardo Posts: 10,634
    edited April 2007
    You need an RCA connector for each channel between the pre and the amp, and then hook up your speakers to the amp.
    Lots of discussions on cables quality/differences, and even more options to choose from. I am happy using Signalcable and Outlawaudio.
    Congrats on your move to better sound ;)
    SOPA
  • danger boy
    danger boy Posts: 15,722
    edited April 2007
    as HTrookie said.. you need an RCA cable for each channel except the subwoofer. subwoofers have their own amps.. so no cable from the pre amp to the amp is needed there. You do need of course a cable from the pre amp to the subwoofer's amp.
    here is one solution for connection your pre amp to your amp for all channels.
    http://www.raymondcable.com/bvc/ProductInfo.aspx?productid=SACD
    PolkFest 2012, who's going>?
  • NeilGabriel
    edited April 2007
    Thanks. To be clear, the RCA connectors are the same (quality aside for the moment) as any other cable you might use to connect cd player or VCR audio to a receiver (and except it is a single strand per channel)? I don't have SW now (yet, the way things are going), but do they also take an RCA connection from the preamp to the subwoofer's amp?
  • zombie boy 2000
    zombie boy 2000 Posts: 6,641
    edited April 2007
    That is absolutely correct. However, a subwoofer interconnect would be appropriate when hooking up your sub.
