12AX7, 12AT7 same thing?
danger boy
danger boy Posts: 15,722
edited April 2007 in Electronics
are these two tubes basically the same? these two are the ones that sound the best in my tube DAC. I tried two 12AU7, but it narrowed the soundfield to much..and the mid-highs were a bit to laid back with that tube.
I had one 12AX7 in the left channel and a 12AT7 in the right channel of my DAC and it really sounded better than I have ever heard it sound.. is it ok to mix these two tubes in one unit?
PolkFest 2012, who's going>?
Post edited by danger boy on
  • Ricardo
    Ricardo Posts: 10,634
    edited April 2007
    The "X" and the "T" have different gain, so it is strange that having one in each channel, you liked it. :confused:
    You can see this info here:
    http://www.thetubestore.com/gainfactor.html
    SOPA
  • danger boy
    edited April 2007
    I know.. freaky huh? but the dac is hooked up to the SRS's. and it give the sound an extra wide and detailed soundstage. I think if it was used in a traditional pair of speakers, it may sound off, but because of the SDA's being what they are and how they work.. it worked fine. ;)
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited April 2007
    Just because your d/a has two tubes, doesn't mean it's use one for each channel, it can be using one triode from both tubes for each channel, each with a different purpose.
    Cheers,
    Russ
  • danger boy
    edited April 2007
    That thought never crossed my mind Russ.. I have some EH tubes arriving today.. i'm looking forward to give those a listen.
