Decent outdoor speakers?
mitiman
mitiman Posts: 2
edited April 2007 in Speakers
Can anybody recommend an outdoor speaker that is decent for pool side?
I plan on hanging them under my soffit.
Post edited by mitiman on
  • pearsall001
    pearsall001 Posts: 5,328
    edited April 2007
    mitiman wrote: »
    Polk Atriums. I have the 45's & they sound great.
    http://www.polkaudio.com/homeaudio/products/multiapplication/
    F1nut Posts: 52,002
    edited April 2007
    Look no further than Polk's Atrium speakers. http://www.polkaudio.com/homeaudio/products/multiapplication/
    F1nut Posts: 52,002
    edited April 2007
    The same answer within seconds of each other, that should tell you something.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited April 2007
    The Atrium are great, if they are in a sofet and weather is not a major concern the Polk ceiling speakers have come light years, they have them for any budget and now have the lsi for a true hi-fi sounding speaker, I am jonesin for some these myself.
    RT1
    F1nut Posts: 52,002
    edited April 2007
    You're at a Holiday Inn Express, aren't you?
