Cambridge DVD Player Resolution
VR3
Was curious if my DVD player could play 1080i resolution?
Post edited by VR3 on
Does it have an HDMI or DVI output?polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
No, just component...
Just curious what the highest resolution it will do?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Just component - then no.
The highest possible resolution you can get via component is 480p. That's why you need to get a DVD player with either a DVI or HDMI output in order to get a 1080i output.
If that's the case, are you still keeping your Azur?polkaudio RT35 Bookshelves
Quick question then -
How is the XBox 360, with just component connection capable of 1080i?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Because the XBox 360's output circuitry transcodes the raw video signal from the graphics chipset into a component signal.
Your DVD Player does not have that capability.
I'm interested in getting a used Azur 540D...polkaudio RT35 Bookshelves
Im not to big into video, but will probally replace it in the future- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I think some players upconvert over component to 1080i. Some HD satellite units and DVD players have component out to 1080i.
But, all upconverting DVD players that upconvert to 1080i will have component and either HDMI or DVI as well. . . so appadv is right as well.Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850 -
Yes, you're right in the fact that if the DVD player is capable of upconverting to 1080i, it will have component and HDMI or DVI.polkaudio RT35 Bookshelves
Vr3MxStyler2k3 wrote: »Im not to big into video, but will probally replace it in the future
Since I'm interested in a used Azur 540D, is there any way that I can buy it when you decide to replace it in the future?
This is one of the *extremely few* players that has an SCART output, which can be used to feed a CRT Projector. (Sony VPH-D50Q)polkaudio RT35 Bookshelves
Do you want to buy it right now? If so email me.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Do I get a 10% fee from brokering (okay, witnessing) this deal?
Hope you guys work out a deal. Everyone wins at Polk Forum. . .
. . . everyone but the losers, that is.Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Vr3MxStyler2k3 wrote: »Do you want to buy it right now? If so email me.
OK, email sent.polkaudio RT35 Bookshelves
