Crap I slipped
CycloneISU
OK long story short I as helping a buddy install his brand new SR 6500 component set in his viper. On the last speaker I slipped :eek: and stuck the 6.5 with my screwdriver, I need only one but am looking for some advice on where to find just one. I really cant afford to buy a complete system myself.
Post edited by CycloneISU on
How bad is the hole? Is it in the surround or the actual cone?Alpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin -
I nailed the cone. I knocked out a pea size hole and cracked it.
lol. Call Polk, they sell each driver separate.
Ouch -- if it was the surround, you could have just got some silicon caulk and dabbled it back together. Ya.. Polk customer service or good ol' ebay dude.The Artist formerly known as PoweredByDodge
You can repair the cone, too.
I ordered a new one only 90.00 to my door. Now I just hope I don't do that again for awhile. What tips can you all give me? I use a hand screwdriver, no power drill. Ive done this before. Just not with this expensive of speakers.
use hex head screws and a 1/4 inch ratchet. if you slip off a hex head, then you've turretts.The Artist formerly known as PoweredByDodge
Drill a hole before you screw it in if you have to. Keep a finger between the speaker and the screw, it hurts, but it saves you $90.
same method I use..Alpine: CDA-7949
Alpine: PXA-H600
KnuKonceptz
Second Skin
