Home Theatre Speaker Advise
giddavr
giddavr Posts: 13
edited April 2007 in Speakers
I love movies and the only way I get to watch English movies is through HT.
I have ONKYO TX – SR 504 AV RECEIVER
OPPO OPDV971H Upconverting DVD Player
SONY Grand Wega 50” KF-E50A10 3LCD RPTV
and need advise regarding the speakers.
Which Polk series will be the Best choice Monitors or the RTi.
Are the RTi worth the extra money
Post edited by giddavr on
  • Early B.
    Early B. Posts: 7,900
    edited April 2007
    Yes, RTi's are worth the extra money.
    Nice TV, by the way.
    "God grooves with tubes."
  • nebborjk
    nebborjk Posts: 425
    edited April 2007
    Early B. wrote: »
    I agree.
    Do you live anywhere near a retailer where you can try them out yourself? Or will this be a blind buy?
    Proud SOPA Member since 2005!
  • giddavr
    giddavr Posts: 13
    edited April 2007
    This will be a blind buy, because the nearest Polk dealer is some 500kms. away.
    If I had the opportunity to hear them I wouldn't be here asking questions.
  • JimBRICK
    JimBRICK Posts: 1,543
    edited April 2007
    Early B. wrote: »
    I second both of those opinions
    2 CHANNEL
    Speaker - Klipsch Heresy II
    Under construction
  • mrbigbluelight
    mrbigbluelight Posts: 9,878
    edited April 2007
    If you aren't hurting for bucks, Rti. List price, not a lot of difference.
    If the piggybank's running low,though, keep an eye out on Fry's for a deal on Monitors. Much bigger difference in price then.
  • danger boy
    danger boy Posts: 15,722
    edited April 2007
    giddavr, welcome.. and where might you live?
    I assume outside the United States :D
    giddavr wrote: »
    PolkFest 2012, who's going>?
  • Sherardp
    Sherardp Posts: 8,038
    edited April 2007
    Welcome aboard, the Rti series are great and will definitely bring spice to the HT party. I went in blind also and from there became a member of the forum as you have and a few months down the road have zero regrets with my purchase or the Polk Family. Stick around, lots to learn and fun to be had here. Oh yeah, nice toys you have in the rack thus far.
  • giddavr
    giddavr Posts: 13
    edited April 2007
    Thanks for the welcomes.
    I live in a small town in the Southern State of Andhra Pradesh in India.
    I can afford the RTis allright, so that is settled.
    The Choice of a SUB remains unsettled as I see the majority NOT using Polk Subs. SVS seems to be a hot favourite but unfortunately they have no dealers in India and shipping costs as much as the sub itself.
  • engtaz
    engtaz Posts: 7,669
    edited April 2007
    What about Velodyne.
    engtaz
  • Sherardp
    edited April 2007
    giddavr you can still try getting an SVS, they use a freight forwarding company called BAX global and are able to ship door to door worldwide. There's one catch, it can be costly, but it depends on just how bad you really want one. I had one shipped to Japan and will have another on the way next month or so. Shipping to Japan was 400 +cost of sub. You can try sending an email to SVS and have them quote you on it plus any voltage configuration you may require.
  • giddavr
    giddavr Posts: 13
    edited April 2007
    Sherardp
    I did write to SVS and they said they can ship it alright and will get back with the shipping costs. Am still waiting for their mail.
    So seems everyone is unanimous about SVS being the Best for the SUB
  • Monster Jam
    Monster Jam Posts: 919
    edited April 2007
    I really like the RTi speaker line.
    As for subs, I can only speak fir the Velodyne brand: well worth the money. Other potentially better value brands may include SVS and HSU.
    Do you hear that buzzing noise? :confused:
  • Shizelbs
    Shizelbs Posts: 7,433
    edited April 2007
    The RTi series is certainly worth the extra money. In my opinion, you should probably get a more powerful receiver. I haven't listened to a Onkyo receiver since the 501/601 systems, but those, while technically can play the RTi speakers fine, if you are spending all that money to begin with, you really should spend a little more for a better receiver.
  • giddavr
    giddavr Posts: 13
    edited April 2007
    Shizelbs wrote: »
    No I cant change the receiver right away.
    If you think RTi need more watts to perform well, would I be better off with the Monitor series.
    What I want to know basically is , with my present set up , wiil RTi series perform equally if not better than Monitors. If so I will buy the RTis and upgrade the AVR later. Otherwise I will buy Monitors.
  • Sherardp
    edited April 2007
    Go ahead and go with the RTi lineup, later on down the road you can go with a power amp. The avr will drive your speakers, no problem for time being.
    Edit: By the way what speakers in the RTi lineup are you considering?
  • giddavr
    giddavr Posts: 13
    edited April 2007
    Sherardp wrote: »
    What combo would you recommend if there were no budgetary constraints
  • Sherardp
    edited April 2007
    Since youre considering a SVS sub, RTi10s,CSi5,FXi5 in 5.1 setup, for a 7.1 add a pair of Rti4s in your rear. Since you say coin is no concern you could always go Rti12s instead of the 10s.
