Speaker choice and placement?*PICS*
Speed3
Speed3 Posts: 91
edited April 2007 in Speakers
My friend is getting a set of RTi12's and a CSi5 soon but is trying to choose between FXi5's or RTi6's for the surrounds. This will be a 5.1 setup for now but will change to a 7.1 later on down the road. Here are some pics of his room. What do you guys recommend for speaker and placement? He will be doing monstly home theater. Click to enlarge.
Post edited by Speed3 on
  • engtaz
    engtaz Posts: 7,664
    edited April 2007
    Good luck
    engtaz
  • Early B.
    Early B. Posts: 7,900
    edited April 2007
    If his setup is mainly for HT, he should go with Fxi5's. The decision basically boils down to preference, though.
    "God grooves with tubes."
  • MADGSF
    MADGSF Posts: 603
    edited April 2007
    I would also go with FXi's for HT.
    AVR: Elite VSX-21TXH
    Amplifier: B&K 7250 Series ii
    Misc: Velodyne SMS-1
    Mains: RTi-10
    Center: CSi-5
    Rear: Boston DSi460
    Sub: SVS PC-Ultra
    TV: Panasonic TC-P58V10
    DVD: Panasonic DMP-BD60K
  • danger boy
    danger boy Posts: 15,722
    edited April 2007
    I would go with the FXi's also for surrounds.. and not even think about 7.1
    the extra power, speaker wire, amps, speakers it takes to wire in two more back surround.. to me just ain't worth it in the long run. my .02
    PolkFest 2012, who's going>?
  • nebborjk
    nebborjk Posts: 425
    edited April 2007
    Another vote for the FXi5's.
    Proud SOPA Member since 2005!
  • Early B.
    edited April 2007
    danger boy wrote: »
    Agreed. Go 5.1 and that's it.
  • engtaz
    engtaz Posts: 7,664
    edited April 2007
    I would vote for 7.1 so I don't have run wire again.
    engtaz
  • crd2002
    crd2002 Posts: 174
    edited April 2007
    I have the same speakers and the FXI's sound great for home theater could't be happier
    I'm considering buying 2 more RTI12's since I have a earthquake 300wpc just to use four of them for 2 channel music
    Home Theater sony 52 inch lcd,Cinenova grande 7 channel, polk RTI8,CSI5,FXI5,onkyo 805
    2 Channel rig Sunfire grand cinema 5ch,sunfire TGA III,Rotel 1072,polk RTI12,Monster hts 5100
  • Speed3
    Speed3 Posts: 91
    edited April 2007
    Thanks guys, I think he is going to order the FXi5's. He is going to mount them on the back wall about 2 feet from the cieling. Does this sound ok?
  • Sherardp
    Sherardp Posts: 8,038
    edited April 2007
    I would a pair FXi5s for sure, as for 7.1 a pair of Rti4s.
  • michael_w
    michael_w Posts: 2,813
    edited April 2007
    He might consider mounting them on the side walls firing towards each other. I used to have my surrounds facing the front and then moved them to the sides and found it to be a nice improvement. It gave it a more spacious feel that also made the transition form the front to back smoother.Three or four feet above ear level should be good.
